use synthetic oil for man tranny fluid?
Old 08-12-2004, 02:04 PM
99cxrico's Avatar
Default use synthetic oil for man tranny fluid?
I had a '97dx and a friend told me to put in synthetic motor oil and I will get smoother shifts, I did. But technically would this cause faster wear on the tranny. would the synchros go out faster
Old 08-12-2004, 02:24 PM
Electrician
Deemeetree's Avatar
Go to your local GM Dealer and pick up some GM Synchromesh Friction Modified and call it a day.
Old 08-12-2004, 02:28 PM
AutoXer's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Go to your local GM Dealer and pick up some GM Synchromesh Friction Modified and call it a day.</TD></TR></TABLE>
http://www.stealth316.com/2-pe...h.htm
Same stuff, cheaper, and you dont' have to go to a dealer.
Old 08-12-2004, 02:31 PM
Electrician
Deemeetree's Avatar
Indeed, Pennzoil does make the GM Synchromesh. But, some stores don't carry it. I need to drive 45 minutes to get the Pennzoil, might aswell go to the GM Dealer 1 mile away and get it from them.
If your local autostore has it, get it. If not, GM Dealer.
Old 08-12-2004, 02:37 PM
99cxrico's Avatar
Default Re: use synthetic oil for man tranny fluid? (99cxrico)
thanx for the info, that synchromesh sounds good I never heard of it before now.
Old 08-12-2004, 03:09 PM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99cxrico &raquo;</TD></TR><TR><TD CLASS="quote">thanx for the info, that synchromesh sounds good I never heard of it before now.</TD></TR></TABLE>
There is no need for teh Friction Modefied i your gears aren't grinding. If you are just looking for smoother shifts pick up either the regular GM Synchromesh, or Honda MTF. If your gears are grinding then go for the Friction Modefied.
Old 08-12-2004, 03:11 PM
Electrician
Deemeetree's Avatar
Default Re: use synthetic oil for man tranny fluid? (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">
There is no need for teh Friction Modefied i your gears aren't grinding. If you are just looking for smoother shifts pick up either the regular GM Synchromesh, or Honda MTF. If your gears are grinding then go for the Friction Modefied.</TD></TR></TABLE>
Why do you say this? Is there anything wrong with placing GM Synchromesh Friction Modified in a non-fucked up transmission? I don't see the point in this statement.
IMO, place the Friction Modified so you can prolong the life of your transmission. Why wait until the synchronizers start going to place Friction Modified in there?
Old 08-12-2004, 03:18 PM
Sliced Beard's Avatar
Default Re: use synthetic oil for man tranny fluid? (Dimi)
hahaha....I just cought something that I found hilarious in that link about Penziol SM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by link provided above &raquo;</TD></TR><TR><TD CLASS="quote">"According to Don Johnson, Synchromesh fluid was developed for use in the New Venture manual transmission"
"now if that aint' funny, I don't know what is"
Old 08-12-2004, 03:32 PM
Electrician
Deemeetree's Avatar
Why is that funny? All of the newer Wranglers come with the NV 5-speed tranny. A lot stronger than the preceeding AX-15 unit. I don't see what's funny about that statement.
Old 08-12-2004, 03:38 PM
meccA's eg6's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Why is that funny? All of the newer Wranglers come with the NV 5-speed tranny. A lot stronger than the preceeding AX-15 unit. I don't see what's funny about that statement.</TD></TR></TABLE>
don johnson
Old 08-12-2004, 03:41 PM
DJ_SaNdOz's Avatar
IMO, place the Friction Modified so you can prolong the life of your transmission. Why wait until the synchronizers start going to place Friction Modified in there?</TD></TR></TABLE>
I say that b/c from what I have read in numerous posts. It seems that the FM version has something in it that actually causes more friction which may result in less lifespan for the tranny, but does increase the smoothness of shifts due to the properties of teh formula. This has been debated before, and if I am wrong, then I am wrong. I personally run Honda MTF in the RSX, and the Synchromesh FM in my EG b/c it had a bad third gear grind.
Old 08-12-2004, 04:01 PM
Default Re: use synthetic oil for man tranny fluid? (Draggin99Si)
it is funny because Don Johnson is an automotive officianato to them.....hahaha
Old 08-12-2004, 04:16 PM
Draggin99Si's Avatar
Is this GM Synchromesh product different from a product called BG Synchroshift?
The DSM crowd seems to love this BG ****. I ordered mine off a DSM site. After doing a tranny fluid change and pouring it in, I can't tell a lick of a difference between this and the Honda MTF at all.
Old 08-13-2004, 04:19 AM
that and they love that royal purple stuff
I am about a half a mile from Slowboy Racing (one of the larger DSM mailorder companies) and they keep this stuff on stock because of the high demand
Old 08-13-2004, 05:20 AM
IVI
IVI's Avatar
Default Re: use synthetic oil for man tranny fluid? (dirtyd463)
4 quarts of honda mtf for sale.
pm me if interested.
Old 08-13-2004, 05:36 AM
i my honda
Global Mod
White Smoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">that and they love that royal purple stuff </TD></TR></TABLE>
Not worth a **** in a honda
Honda MTF ONLY
GM Synchromesh is my 2nd choice.
15w-30 valvoline Non-Synthetic is my 3rd choice.
DO NOT RUN SYNTHETIC OIL IN A HONDA TRANS!!!!!!!
BLUE EH3
26
08-08-2006 01:33 PM
si0385.
12-27-2005 03:21 PM
eluder33
02-08-2005 07:33 AM
BahamaEKcrvtec
01-05-2005 05:06 PM
Sephro
07-24-2003 04:01 PM
Quick Reply: use synthetic oil for man tranny fluid?
