Type R motor Skunk2 Pro 1's with fuel pressure problems...
Old Apr 2, 2008 | 05:18 PM
Kahki Hatch's Avatar
Default ---Type R motor Skunk2 Pro 1's with fuel pressure problems... NEED HELP ASAP!
Motor: B18C5 Integra Type R
Mods: "Rocket" full valve train with Skunk2 Pro 1 cams, STOCK block
Engine management: Apex'i Power Fc with the stock B16B fuel map and ignition map
Important info: I have the Type R motor from an '00 Type R. The motor came without the exhaust header and intake manifold. I am currently using my OLD stock <u>OBD1 B16A</u> intake manifold. Along with this I am using an <u>OBD0 / 4th</u> gen Civic fuel line/ fuel rail.
Problem: Motor idles fine at first, but after 7 mins, the idle goes from roughly 300 rpms to 1,000 rpms. Normal idle is roughly 650-800 rpms, from what I have noticed. Fuel pressure consistently jumps from 50psi to 60 psi. This jump in fuel pressure could also be causing the idle problem. There is also an awkward "knock" / noise coming from the head right off of the dizzy.
I haven't driven the car much / hardly at all due to the larger cams and I'm not wanting to hurt anything motor wise.
Any info is appreciated and thank you in advance.
Modified by Kahki Hatch at 7:30 PM 4/2/2008
Old Apr 2, 2008 | 05:49 PM
93egSLEEPER's Avatar
Default Re: Type R motor Skunk2 Pro 1's with fuel pressure problems... (Kahki Hatch)
my engine had the same problem when i finished my swap (JDM B16) and i turned the idle control screw all the way down and it runs fine now. when you get it tuned you can have the idle adjustd also. give it a try
Old Apr 2, 2008 | 05:57 PM
z6hatchboy's Avatar
Default Re: Type R motor Skunk2 Pro 1's with fuel pressure problems... (93egSLEEPER)
I with you on this, i've had a similar problem and idle adjustment did help it.
Old Apr 2, 2008 | 06:09 PM
Default Re: Type R motor Skunk2 Pro 1's with fuel pressure problems... (z6hatchboy)
I've also heard since the motor has "larger" cams and that it is untunedm that this could be the problem as well...
We'll see in a week or so when it gets tuned.
I'm still wanting to hear other opinions please.
Old Apr 2, 2008 | 07:51 PM
bump... Any ideas guys?
Old Apr 2, 2008 | 07:57 PM
slo_ej8's Avatar
get it tuned
Old Apr 3, 2008 | 01:55 PM
bump
Old Apr 3, 2008 | 06:07 PM
anymore help is useful
GsrIntegra789
Jun 4, 2008 04:00 PM
Teamdiesel
11
Nov 11, 2007 05:39 PM
Ruben19
Oct 11, 2006 08:30 AM
B_1_8_hatch
Apr 23, 2004 02:22 AM
93SSPHatch
Jul 18, 2002 03:18 PM
