shimming oil pump on d series.
Old Jul 10, 2002 | 08:46 AM
SoloSol's Avatar
Default shimming oil pump on d series.
I thought there was a way on b-series some site somwhere. But is there a way to do this on a d-series.
Old Jul 10, 2002 | 11:19 AM
Steve91's Avatar
Default Re: shimming oil pump on d series. (SoloSol)
Just so you know, when you increase oil pressure, you DECREASE oil flow volume.
Old Jul 10, 2002 | 03:08 PM
SoloSol's Avatar
Default Re: shimming oil pump on d series. (Steve91)
Is there a way to increase both?
Old Jul 10, 2002 | 03:23 PM
Spade's Avatar
Better oil pump.
I haven't found one yet.
Old Aug 7, 2003 | 11:44 AM
SloCivicHMM's Avatar
Default Re: shimming oil pump on d series. (Spade)
Hmmmm old thread.....how can I get more oil in my d series....so that everything stays lubed!!
Old Aug 7, 2003 | 12:06 PM
civic-4-ges's Avatar
Default Re: shimming oil pump on d series. (SlowCivicHmm)
Add a second, electric oil pump, and a second reservoir
Old Aug 7, 2003 | 12:16 PM
Zer0DazE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoloSol &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way to increase both?</TD></TR></TABLE>
read the write up on the endyn site.
Old Aug 7, 2003 | 12:45 PM
Default Re: shimming oil pump on d series. (Zer0DazE)
link anyone???
Old Aug 7, 2003 | 01:35 PM
Steve91's Avatar
To shim a typical pump, you remove the threaded plug that has the pressure bypass spring. You then put in a shim or washer, usually about 1mm thick, between the spring and the plug and screw it back together. This raises the pressue on the spring, thus allowing more oil pressure to build.
Do you need to do this? I don't think so. For one, more oil pressure = less horse power. You only need about 8-10psi per 1000rpms, and that generally tops out at 60-80psi. Anything more than that provides no benefit. My stock D16 pump provides 80psi above 3000 rpms.
240 killer
Sep 15, 2012 08:57 PM
JDMCRX
Feb 19, 2008 03:43 AM
Circuit Star-29
May 5, 2006 09:40 PM
d.str0y
Jan 24, 2005 05:36 PM
-KangaRod-
Mar 22, 2004 02:52 PM
