B20B Questions
Old Apr 2, 2008 | 01:28 PM
shinji666's Avatar
Default B20B Questions
I have a 98 CRV with a B20B engine (rated 126hp). I did some research and found out that it the difference between B20B and B20Z is the CR (pistons) and the intake manifold. I will be rebuilding the engine pretty soon since its at 290000km right now and im wondering if i just use pistons from b20z, would it work in b20b w/o modifcation? Will it bolt in directly?
Old Apr 2, 2008 | 06:58 PM
blkb18's Avatar
Default Re: B20B Questions (shinji666)
I am not 100% sure, but I believe you can. The two engines are identical with exception of piston, im and knock sensor. I would look into weather or not the cams are the same. But as far as the pistons fitting on the rods you should be good, the head castings I believe are the same so the combustion chamber should be good with either piston. Like I said make sure that your cams dont have a higher lift or durration than the b20z (but I dont think they would). Always good to double check.
typeR4u
11
Feb 25, 2015 06:31 AM
070-racing
Oct 26, 2014 04:55 AM
Honda_Cribb_GS-R
21
Nov 27, 2009 10:00 AM
ras
Dec 10, 2003 06:48 PM
TypeR0wnz
Feb 15, 2003 03:46 AM
