How can I replace sway bar end links?
Old Apr 2, 2008 | 11:21 AM
dragostefatala's Avatar
Default How can I replace sway bar end links?
I have a '99 Accord LX 4d/4cyl and the sway bar end links are kind of loose. How difficult is it to replace them? Any instructions anywhere?
Thanks a bunch.
Old Apr 2, 2008 | 05:01 PM
hondadude's Avatar
Default Re: How can I replace sway bar end links? (dragostefatala)
Gravy job. You have to hold the link stud with an allen key while removing the nut.
Sometimes it makes it easier to re-install the end links if you loosen the swaybar mounts.
Old Apr 3, 2008 | 05:38 AM
AFAccord's Avatar
Default Re: How can I replace sway bar end links? (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Gravy job. You have to hold the link stud with an allen key while removing the nut.
Sometimes it makes it easier to re-install the end links if you loosen the swaybar mounts.</TD></TR></TABLE>
+1 I was messing with these a couple weeks ago, and I believe it was a 5.5mm key.
Old May 28, 2008 | 11:22 PM
spinimbus's Avatar
Default Re: How can I replace sway bar end links? (AFAccord)
I just did this today as well. I was wondering if lube was necessary or will they squeakiness go away eventually. Also is there a torque spec for it or just tighten to the fullest. Thanks in advance.
marks97el
Sep 4, 2010 02:07 PM
LukieLuc
Jul 31, 2007 09:24 AM
jlcljayne
Jan 13, 2006 03:47 PM
a1k0n
Feb 17, 2002 08:57 PM
a1k0n
Feb 17, 2002 12:38 PM
