VTEC pressure valve ecu code
Old Apr 1, 2008 | 09:57 PM
keychild486's Avatar
Default VTEC pressure valve ecu code
I just put together my ls/vtec set up. i put a new valve train in with stock cams and everytime i hit vtec in 3rd gear i get a "VTEC pressure valve" code. the code came up on my first vtec solenoid and i changed the solenoid and now the code is still popping up with the new vtec solenoid. i was wondering if this happen to anybody and what did they do to solve the problem.
Old Apr 1, 2008 | 10:06 PM
mtber's Avatar
Default Re: VTEC pressure valve ecu code (keychild486)
What ecu are you running ?
What vtec solenoid are you running (jdm or usdm) ?
Old Apr 1, 2008 | 10:09 PM
B16EJ1EG6's Avatar
What code number?
Old Apr 1, 2008 | 10:12 PM
Default Re: VTEC pressure valve ecu code (mtber)
its a chipped p28
Old Apr 1, 2008 | 10:13 PM
the original solenoid was us and i replaced it with jdm and still getting the same result
Old Apr 1, 2008 | 10:14 PM
code 22
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keychild486 &raquo;</TD></TR><TR><TD CLASS="quote">the original solenoid was us and i replaced it with jdm and still getting the same result</TD></TR></TABLE>
A jdm solenoid does not have a vtec pressure switch.
Bypass the vtec pressure switch per the instructions on http://www.phearable.net/tech
Old Apr 1, 2008 | 10:22 PM
which link do i click on for directions. also which switch is the oil pressure switch on the solenoid the green or the gray switch?
Old Apr 1, 2008 | 10:23 PM
B16EJ1EG6's Avatar
FOSHO!! Bookmarked!
Old Apr 1, 2008 | 10:24 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keychild486 &raquo;</TD></TR><TR><TD CLASS="quote">which link do i click on for directions. also which switch is the oil pressure switch on the solenoid the green or the gray switch?</TD></TR></TABLE>
Click on "How to bypass vtec oil pressure switch"
Old Apr 1, 2008 | 10:36 PM
thank you very much for your info one more question i know the jdm solenoid doesn't have a oil pressure switch so you mean when the code came up for the usdm solenoid does that mean my usdm solenoids oil pressure switch wasn't working?
Old Apr 2, 2008 | 06:28 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keychild486 &raquo;</TD></TR><TR><TD CLASS="quote">thank you very much for your info one more question i know the jdm solenoid doesn't have a oil pressure switch so you mean when the code came up for the usdm solenoid does that mean my usdm solenoids oil pressure switch wasn't working?</TD></TR></TABLE>
Possibly.
PnkRokCountryboy
Sep 2, 2007 02:21 PM
rigles1
May 13, 2006 08:02 PM
VTC_CiViC
Nov 17, 2004 09:05 PM
