squeeling noise from timing belt
Old Apr 1, 2008 | 06:20 PM
civicstar's Avatar
Default squeeling noise from timing belt
i have a gsr motor and reset the cam gears back to zero and redid timing and after there was a squeel from the timing belt area, it seems like its near the cam gears. i checked if it was the alternator belt but its not, ive adjusted to see if it was but not noise from that. i even took the plastic piece on the back of the cam gear on the head off because i thought it was that but it still didnt solve the problem. when i first start it, it doesnt make the noise but after idling for 15 sec it comes after the idle goes down alittle bit. the car does not have a fluctuating idle and it idles at around 800 rpms when warm and around 1000-1200 when cold
* i only have alternator belt, no ac, no PS*
Old Apr 1, 2008 | 06:50 PM
NJIN BUILDR's Avatar
Default Re: squeeling noise from timing belt (civicstar)
How old is the tensioner?
Old Apr 1, 2008 | 08:42 PM
civicstar's Avatar
Default Re: squeeling noise from timing belt (NJIN BUILDR)
well its a few years old, im starting to think its the tensioner too, could there be anything else if thats not the cause
Old Apr 1, 2008 | 08:46 PM
HONDAPARTSMANMIKE's Avatar
hows the water pump??
Old Apr 1, 2008 | 08:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">well its a few years old, im starting to think its the tensioner too, could there be anything else if thats not the cause</TD></TR></TABLE>
you could also run the car for a few minutes with out any drive belt to be sure its coming from the t iming belt area
Old Apr 1, 2008 | 09:42 PM
civicstar's Avatar
Default Re: squeeling noise from timing belt (HONDAPARTSMANMIKE)
the water pump is good, no problems there, ive tried without the alternator belt on a charger and it still made the noise, its odd cuz i set the camgears to zero and for some reason i have to fully advance the dist timing for it to run adn idle it normally, i dont have a timing light at the moment so i cant see the degrees,
extra info:
(i have skunk2 cam gears and i have them both on the middle mark, if i count the marks there are a total of 11 and its on 6th mark, 5 on one side , 5 on the another so the 6th is the middle) it started making noise when i put the cam timing back to zero, if i should should i advance or retard the exhaust cam (it seems like a stock motor with just skunk2 intake manifold and skunk2 cams
should i advance or retard the intake cam
when i got the motor the timing on the cams were not set on zero, it was either advanced or retarded one mark on each
when i took the cams off, i forgot to check the rings on the camshaft but i remember seeing a G on the middle marking
Modified by civicstar at 11:16 PM 4/1/2008
Old Apr 7, 2008 | 11:58 PM
civicstar's Avatar
fixed it, it was just the cam gears making the belt squeek
Old Apr 16, 2009 | 07:43 PM
nogutsnoglory77's Avatar
how did you fix this problem?
ceehris
Dec 13, 2006 10:10 AM
hondaracin24
Oct 29, 2006 01:20 AM
mojo_stevo
Oct 3, 2006 04:10 PM
BOOSTEDgreeneg
May 25, 2005 12:51 AM
Big Teggie
Jan 2, 2003 04:47 AM
