check engine light on code 7 tps
Old Apr 1, 2008 | 02:48 PM
superhatchbackbros's Avatar
Default check engine light on code 7 tps
i have a 96 hatch with h22 swap and im geting a code 7 for tps i have extra tps for d series will this work? are all 92-00 tps d.b.h the same? please get back to me if anyone knows, thanks in advanced.
Old Apr 1, 2008 | 03:07 PM
Luserkid's Avatar
Default Re: check engine light on code 7 tps (superhatchbackbros)
98% sure it will work
Old Apr 1, 2008 | 08:15 PM
bump ttt anyone else? need help
Old Apr 1, 2008 | 10:06 PM
highrev98civic's Avatar
your tps on your swap should still be good did you calibrate it yet? if not it will throw a code
Old Apr 1, 2008 | 10:10 PM
what u mean calibrate it? give me details?
Old Apr 1, 2008 | 11:34 PM
562daybid's Avatar
* B A N N E D *
well your getting a code for the tps because you need to adjust it correctly.. you need a multimeter.. you cant just put on a new tps sensor.. it will give you the same code 7 and your car will idle really high.. and yes a d series tps will work... I took one of my single cam and used it for my gsr.. works fine.. still not the right adjustment I believe but Ill use it for now until I know how to adjust the tps to the proper settings..
Old Apr 2, 2008 | 06:22 AM
Default Re: (superhatchbackbros)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superhatchbackbros &raquo;</TD></TR><TR><TD CLASS="quote">what u mean calibrate it? give me details?</TD></TR></TABLE>
i searched and found this but i stil need a little help
but i only see 3 holes to check voltage the green wire is comming up .5
but the other 2 dont show anything with the car off can some one help me out am i doing somthing wrong or is my tps just bad?
You need to connect a multimeter to the tps and move the sensor around until the correct ohm specs are achieved.
With the TB closed, sensor disconnected, ign off:
Pins 1 and 2 = 0.5-0.9ohms
Pins 2 and 3 = 3.6-5.4ohms
You also need to be sure you have correct voltage, sensor connected, ign 'on':
Pins 1 and 3
0.5volts with the TB closed
4.5volts with the TB fully open
Mr.Death
Apr 30, 2010 05:51 PM
gettin it
10
Jan 4, 2008 06:53 AM
skiracer8148
Aug 2, 2006 03:26 AM
psegs80
Jul 15, 2005 05:07 AM
