sensor question
Old Apr 1, 2008 | 02:07 PM
juanintec's Avatar
Default sensor question
where is a knock sensor in a 2000 si???
what sensor is the one in the lower left side of the engine by the pully on a 2000 si motor??
Old Apr 1, 2008 | 02:23 PM
yoffer's Avatar
Banned
THe knock sensor is located on the back on the block underneath the intake manifold.
That sensor down by the pulley might be the crankshaft position sensor.
Old Apr 1, 2008 | 09:41 PM
juanintec's Avatar
Default Re: (yoffer)
yeah but i looked in alldata and it said the knock sensor is in the lower left
there are 2 sensors in the 2nd pic there should be 3 right??
Old Apr 1, 2008 | 10:29 PM
EJ8 944's Avatar
Default Re: (juanintec)
i believe the knock sensor is the one between the water jacket and the intake manifold
Old Apr 2, 2008 | 09:08 AM
juanintec's Avatar
Default Re: (EJ8 944)
yeah thats what i think too
but what sensor is the one behind the pully??
does a bod1 wiring harness have a sensor for that sensor behind the pully??
the motor is a 2000 si b16
Old Apr 2, 2008 | 10:00 AM
shaggyeg6si's Avatar
No, obd1 civics got their signals, such as the crank sensor, in the dizzy. get an obd1 b16 dizzy, to go with your obd1 harness.
Old Apr 2, 2008 | 11:41 AM
EJ8 944's Avatar
the one by the pulleys is the crank position sensor, i think that was an obd2 only thing, with that being said, there shouldnt be a clip for it on your obd1 harness
Old Apr 2, 2008 | 11:56 AM
juanintec's Avatar
so the obd1 does not have it??
so i should do the swap just ignore the sensor then huh??
Old Apr 2, 2008 | 11:58 AM
juanintec's Avatar
so what is the diffrance of crank position sensor and crank fluctuation sensor
Old Apr 2, 2008 | 01:07 PM
Bakeoff's Avatar
slow down chief. What engine in what car with what harness, distributor, ecu?
Old Apr 2, 2008 | 01:14 PM
juanintec's Avatar
Default Re: (Bakeoff)
well its a 96 hatch
it has a obd1 wiring harness
and Im swaping in a b16a2 from a 2000 civic si
and i will use a b16 obd1 dizzy
and ill go with a p30 ecu(dont have it yet)
and it all wired up for vtec, so ive been told i just got the car like a month ago
hoezee
Oct 6, 2008 10:40 AM
NA JDM GSR
Apr 19, 2007 01:17 AM
odyssey2001
Acura TL, RL & ZDX
Dec 31, 2005 08:24 AM
SC94DB8
Oct 22, 2002 11:16 AM
