type r suspension question!!!
Old Apr 1, 2008 | 10:33 AM
gsrpedro's Avatar
Default type r suspension question!!!
im about to put the type r suspension on my EF but i wanna know if i need to put the integra master and B/B i know i have to install the PPV thanks guys
Old Apr 1, 2008 | 10:39 AM
sgallagher's Avatar
Default Re: type r suspension question!!! (gsrpedro)
Yes. The master cylinder is larger for type R brakes.
It will work without swapping the master cyl or proportioning valve, just not efficiently. I wouldn't recommend it.
Old Apr 1, 2008 | 10:47 AM
CRX Toad's Avatar
Default Re: type r suspension question!!! (sgallagher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgallagher &raquo;</TD></TR><TR><TD CLASS="quote">Yes. The master cylinder is larger for type R brakes.
1. You must swap booster and MC together, you cannot put a a MC from a Civic on a Type-R Booster
2. If you are swapping braking systems you need to mimic the vehicle that it is coming off of
3. If you are putting on bigger brakes and have a small MC you may run out of pedal travel before your brakes actually stop you, hence reason #2 applies.
Old Apr 1, 2008 | 10:51 AM
gsrpedro's Avatar
Default Re: type r suspension question!!! (CRX Toad)
so if i put the integra master and the B/B ill be fine?
Old Apr 1, 2008 | 11:11 AM
gsrpedro's Avatar
yes no maybe????
Old Apr 1, 2008 | 11:30 AM
90efhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">
3. If you are putting on bigger brakes and have a small MC you may run out of pedal travel before your brakes actually stop you, hence reason #2 applies.</TD></TR></TABLE>
Like toad said use the master cylinder and brake booster that goes with the brakes that you are putting on the car. If you are swapping on type r brakes then use the bb and mc. you need the proportioning valve off of the integra also. I would suggest some stainless braided brake lines also.
Old Apr 1, 2008 | 11:31 AM
CRX Toad's Avatar
And Integra Booster and MC will bolt on no problems. There are two kinds an ABS unit and NON-ABS unit. You CANNOT put a ABS booster with a NON ABS master cylinder it WILL NOT WORK, or vise versa.
The ABS unit will say 290v on a tag on the top of the booster
The NON ABS unit will say 260v on that tag on top of the booster
If you have a 290 (ABS) you will need the fitting from the rear line on the MC to put on the rear line on the car you are bolting this onto. This will require cutting and reflaring the new fitting on your car which is not hard to do. We have done this with so many CRX that it is very simple.
Old Apr 1, 2008 | 11:38 AM
gsrpedro's Avatar
oh ok thanks imma go to the junk yard and get the 90 integra non abs master and B/b i already have the PPV
airforce21
Suspension & Brakes
Jul 17, 2011 02:48 PM
krazyhmongboi
Jul 10, 2008 08:40 PM
Lost_clearance
Jun 21, 2007 05:24 PM
leboeuf45
Jun 19, 2005 03:45 PM
GQ Cowboy
Aug 21, 2002 07:15 PM
