Please help. Motor won't crank.
Old Mar 31, 2008 | 06:01 PM
Root of all Evil's Avatar
Default Please help. Motor won't crank.
Hi I'm having problems cranking my freshly sleeved 83mm b18c5 in a dc2r. So when I try to crank the motor I just hear a click and then sometimes just the starter spins but the engine doesn't crank. I have been over all wiring and grounds and all is well. I removed the starter and tested it by jumping the ignition and the gear spins and moves out. What could be wrong? Also i checked tdc and flywheel teeth and I checked to make sure the outer flywheel gear isn't moving independant of the rest of it. Please any help is appreciated.
Old Mar 31, 2008 | 07:20 PM
On a side note. Why are starters so expensive? $300 oem? [freak]
Old Apr 1, 2008 | 12:05 PM
Perfectionist's Avatar
Default Re: Please help. Motor won't crank. (Root of all Evil)
The starter motor may be good, but what about the starter solenoid? It may be intermittent enough that it works while on the bench but not while installed. Or, you overlooked a wiring mistake afterall. A spinning starter without engaging flywheel could be gummed up bendix?
Old Apr 1, 2008 | 03:48 PM
ordered new starter will install tomorrow. What is a gummed up bendix?
Old Apr 1, 2008 | 04:04 PM
superfast666's Avatar
Default Re: (Root of all Evil)
u should have tried to push start it before u bought a starter what if it is not the starter could have been lose ecu ground which connects on the thermostat housing
Old Apr 1, 2008 | 04:17 PM
the motor is 100% new and I want to crank it it to build some oil pressure before I fire it. So unfortunately I need the starter. I toned the grounds and all is well.
Old Apr 2, 2008 | 06:47 PM
new starter solved it motor is alive and I hate electrical gremlins.
dmanfree
Jun 21, 2013 12:38 PM
h22a_black
Feb 13, 2008 06:12 AM
97LXAcc0rd
Sep 28, 2005 11:18 AM
GQ 05YellowEVO8
Aug 12, 2002 07:08 PM
