egt or a/f gauge? pleae help!
i know this topic's been covered before but i'm getting alot of mixed opinions and pretty much lost now. since i'm a noobie and don't know all that much about tuning, i figured a/f guages will be easier for me to read(and better looking w/ all the lights and everything
) but i'm told a egt is much more reliable/accurate. i thought about autometer a/f and i heard they suck, just like the egt/pyrometer. can you guys give me gauge parts list that wont break the bank and be able to monitor my engine pretty well hopefully under 2 mr. ben franklins?
If you aren't willing to spend money on a good AF meter your best bet would be to get an EGT. The combo of a GOOD A/F meter and EGT is unmatchable. A A/F meter that does not have it's own heated, wide band sensor and signal amplifier/heater control circuitry is nothing more than an idiot light.
i emailed halmeter.com and they told me that the new meters will work w/ the stock sensor? should i still get one from them? also, i'm not planning on doin my own tuning so what can i use just get by in monitoring what's goin on under the hood. also, do you think i should go w/ hondata2b or the vafc hack? i know hondata is better but i figure if i get the msd 6btm and vafc, i would be able to install it myself and be more of a learning experience. what do you guys think?
btw, how are blitz egt gauges? are they reliable/accurate? here is a pix of the one i'm considering on buying
http://photos.yahoo.com/bc/theory48/...c=ph%26.view=t
you know what i ahve no idea either, how can you tell if your running lean or rich based on a pyrometer? lean= hot, rich=cold? Can some one set me sraight?
thanks all
Rob
thanks all
Rob
thanks all
Rob
thanks all
Rob
Sometimes overly rich conditions cause high ex temps and this condition can only be identified with a AF meter/EGT combo (or a good datalogger).
