CAR WONT STARTT!!
Old Mar 31, 2008 | 10:41 AM
d16turbocoupe's Avatar
Default CAR WONT STARTT!!
i install a d16y8 head on a d16z6 block but when i try to start it.. it wont start it cranks and all but it wont turn over and start... any suggestions anibody!!!
Old Mar 31, 2008 | 10:46 AM
crazyguy's Avatar
Default Re: CAR WONT STARTT!! (d16turbocoupe)
check the starter, does fuel pump prime?
Old Mar 31, 2008 | 10:55 AM
starter is good.. still new, the fuel pump does prime.. i can hear it.
Old Mar 31, 2008 | 10:59 AM
crazyguy's Avatar
Default Re: (d16turbocoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16turbocoupe &raquo;</TD></TR><TR><TD CLASS="quote">starter is good.. still new, the fuel pump does prime.. i can hear it. </TD></TR></TABLE>
all the fuese good? all ground wires good? main relay good ?
Old Mar 31, 2008 | 11:03 AM
all of that is still good.. what could be the problem!?!?
Old Mar 31, 2008 | 12:13 PM
Former User's Avatar
Check for spark at each of the plugs.
Old Mar 31, 2008 | 12:31 PM
boosted92hatch's Avatar
Default Re: (RonJ@HT)
worstswap ever. however when i did it a few years ago mine wouldnt start, 2 reasons, u have to have the timing dead on because they do not line up perfect. when the car is off it will be a tooth out of timing. there is no fix and when rpms go up timing just gets worse. there are a hundred write ups about why not to use a y8 head on z6 block and vice versa. also make sure all your grounds are good. and connected. if they dont work check the distributor. you are useing the y8/y7 distributor, correct!!. if that dont work then make sure all your wires are connected. u didnt forget the plugs or anything stupid did u. everyone makes a mistake now and then.
Old Mar 31, 2008 | 12:33 PM
Default Re: (boosted92hatch)
also when u repinned the distributor did u put all the same wires back because they are different. they switched up some wire colors from 95-96
heeltoehonda
Dec 5, 2009 11:39 AM
naler62188
Sep 9, 2008 02:06 PM
matmcg
Feb 17, 2008 03:34 PM
evoalf
Sep 4, 2004 06:21 AM
lazykiwi
May 13, 2004 11:55 PM
