White SMOKE!!!
White smoke...I just finished fixing up my car because of a recent headgasket problem. I have replaced almost everything, new headgasket,valve seals, exhaust and intake gasket,water pump and timing belt. I also did resurface the head and torque everything to specs. The coolant level was ok and oil level is ok and it's not milky like when i had that blown headgasket.I'm afraid to drive it around because of the thick smoke that's coming out of the exhaust.need help pls.
was the HG bad when you did all this work? If so how long did you let it run? I just changed mine and if you still have a lil water in it then you have to let it burn it out. I let mine idle for about 20min to let it heat up and get a good seal and it smoked but after I let it cool down and started it up again it seemed to be fine.
Dyzee
Jun 4, 2004 03:55 PM
