Wiring AC Switch to ECU for High/Low Boost Settings?.... need a little help plz
Old Mar 31, 2008 | 07:05 AM
96 GSR-T's Avatar
Default Wiring AC Switch to ECU for High/Low Boost Settings?.... need a little help plz
Here is a diagram that I just drew of the system, is the way I have it written below the correct way to wire it? I was told the switch is just Power, Ground In and Ground Out. I know the BLK/YEL is Power and my assumption is BLU/RED is Ground IN and GRN Ground Out, is this correct?
I am assuming I cut the Green and wire it to B5 on my ECU and cut BLUE/RED and ground it to chassis, is this correct? Am I supposed to leave the 12v BLK/YEL attached to the switch?
Thanks Tremendously!
Modified by 96 GSR-T at 6:13 PM 3/31/2008
Old Mar 31, 2008 | 03:38 PM
havok hybrid's Avatar
Default Re: Wiring AC Switch to ECU for High/Low Boost Settings?.... need a little help plz (96 GSR-T)
you need a replay..
that is all.
ecu .. relay.. 12v or grounded switch.. = done
Old Mar 31, 2008 | 04:18 PM
96 GSR-T's Avatar
Default Re: Wiring AC Switch to ECU for High/Low Boost Settings?.... need a little help plz (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">you need a replay..
that is all.
ecu .. relay.. 12v or grounded switch.. = done </TD></TR></TABLE>
why do I need a relay to do this when nobody else does?
Old Apr 1, 2008 | 03:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">
why do I need a relay to do this when nobody else does?</TD></TR></TABLE>
Your AC swtich is only.. a Switch.. right.
Then you use a relay.. to turn on power . or ground on .. Right???
I didnt notice you were trying to use the OEM harness.. I was focused on making the ECU pin work with a switch.
Old May 7, 2011 | 08:24 PM
Lazysk8r2's Avatar
bump, im trying to do the same thing but in an EM1. Anybody know how?
nitewolf
12
Nov 21, 2009 08:55 PM
96 GSR-T
Mar 31, 2008 06:55 AM
nickoz
Mar 14, 2008 04:06 PM
zdr262
Apr 18, 2002 05:25 PM
