Best way to tap into my valve cover for oil catch.
I need to put 90 degree fittings into my valve cover and dont want to weld becouse it was just freshly powdercoated. I was thinking eather prilling a hole and tapping it adn using a hole bunch of teflon tap. eather that or drill a gold just a little bigger than the treds so i can put it in with a rubber washer on each side adn then hold it there with a thin nut on the other side...what do you think i should do? is there an easyer way? lmk
THX
THX
drilling and tapping the hole NPT isnt the best idea since the valve cover is pretty thin (about 1/8" thick)
I would also suggest using a bulkhead fitting or possibly 90 deg o-ring boss and use a bulkhead nut to secure it so the o-ring would help from oil/ vapors leaking past the fitting.
this
and this
since the valvecover is so thin there shouldnt be a problem threading the bulkhead nut onto the ORB fitting.
Modified by robx7fcna at 5:56 PM 3/30/2008
this
and this
idk if this idea of the nut will work anymore. i just remebrd that there is a baffle rivited in there. I wouldnt be able to get around it with out having to take it off. I mite just have to tap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scspeed »</TD></TR><TR><TD CLASS="quote">idk if this idea of the nut will work anymore. i just remebrd that there is a baffle rivited in there. I wouldnt be able to get around it with out having to take it off. I mite just have to tap</TD></TR></TABLE>
Probably not enough material there to get a strong bite on a NPT fitting if you tap it. Stop being cheap and weld some fittings in there and get it re-powder coated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote"> Probably not enough material there to get a strong bite on a NPT fitting if you tap it. Stop being cheap and weld some fittings in there and get it re-powder coated. </TD></TR></TABLE>
kreatekustomz
May 21, 2010 09:11 PM
aleks77
Sep 4, 2008 09:35 PM
aleks77
May 23, 2007 06:53 AM
