!HELP! Main relay issuse. please help.
Old Mar 30, 2008 | 03:06 PM
MR.johnson's Avatar
Default !HELP! Main relay issuse. please help.
the main relay just buzzes and growls, the checkengine light comes on but is dim, fuel pump does not prime.
no battery light or oil pressure light comes on.
great grounds, 12.5v at the fuse box and battery.
please help.
thanks.
Old Mar 30, 2008 | 03:10 PM
Former User's Avatar
Default Re: !HELP! Main relay issuse. please help. (MR.johnson)
Is it possible that the battery terminals and connectors need cleaning?
Have you tried to retrieve the CEL code?
Old Mar 30, 2008 | 03:21 PM
MR.johnson's Avatar
Default Re: !HELP! Main relay issuse. please help. (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible that the battery terminals and connectors need cleaning?
Have you tried to retrieve the CEL code?</TD></TR></TABLE>
yes voltage is perfect.
the cel light is on because the fuel pump is not priming...
Old Mar 30, 2008 | 03:33 PM
I am not sure what year/model Civic you have, but it may be worth troubleshooting the main relay and the fuel pump circuit with a multimeter.
The fact that the CEL is dim, however, may indicate a more general electrical wiring/ground issue.
Old Mar 30, 2008 | 03:50 PM
MR.johnson's Avatar
i need this thing to run. damn.
Old Mar 30, 2008 | 03:51 PM
fiveten's Avatar
replace the relay
Old Mar 30, 2008 | 03:52 PM
MR.johnson's Avatar
Default Re: !HELP! Main relay issuse. please help. (fiveten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiveten &raquo;</TD></TR><TR><TD CLASS="quote">replace the relay</TD></TR></TABLE>
i did.
Old Mar 30, 2008 | 03:53 PM
fiveten's Avatar
What r we working on?
Old Mar 30, 2008 | 03:54 PM
MR.johnson's Avatar
93 civic. b16 swap.
Old Mar 30, 2008 | 03:57 PM
fiveten's Avatar
What ecu and what engine and interior harness do you have
Old Mar 30, 2008 | 04:56 PM
MR.johnson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiveten &raquo;</TD></TR><TR><TD CLASS="quote">What ecu and what engine and interior harness do you have</TD></TR></TABLE>
stock b16, stock harness, stock chassis harness.
Old Mar 30, 2008 | 05:59 PM
Here's how to troubleshoot the main relay/fuel pump circuit:
Old Mar 30, 2008 | 06:30 PM
MR.johnson's Avatar
thanks i will try it.
Old Mar 30, 2008 | 06:31 PM
MR.johnson's Avatar
thats only for the fuel pump... i need one for the main relay... theres no spark too...
Old Mar 30, 2008 | 06:43 PM
Here you go:
Old Mar 31, 2008 | 12:26 AM
MR.johnson's Avatar
damn. thank you.
Old Mar 31, 2008 | 04:31 AM
MR.johnson's Avatar
any more ideas?
Old Mar 31, 2008 | 11:46 AM
MR.johnson's Avatar
111
Old Apr 1, 2008 | 02:11 PM
MR.johnson's Avatar
its a no go... anyone else have any ideas?
Old Apr 1, 2008 | 04:27 PM
MR.johnson's Avatar
Kanjo
Sep 17, 2020 03:12 PM
nickhemeon2133
Honda Civic (2001 - 2005)
Oct 12, 2018 05:18 AM
Mike"IAMSLOW"Myers
Mar 30, 2008 06:07 PM
_Spugen_
19
Aug 8, 2005 01:59 PM
chad
Oct 6, 2003 04:56 PM
