Turbo D16 Back from the Track. Broken Trans haha.
Old Mar 30, 2008 | 11:29 AM
Dr. D-Series's Avatar
Default Turbo D16 Back from the Track. Broken Trans. *Pics up*
First run was more or less a test pass. I launched way too soft. Im used to preloading and launching on my rev limiter.
Now that Ive got an anti-lag its totally different. I didnt build enough boost and just bogged out of the hole. Hence the 1.999 60 ft.
Second run wasnt much better. I busted my 2nd gear in the burnout box. My own mistake. Ive been told not to shift in the burnout. But I did, and I felt something break.
I launched a bunch better on 2nd run with a 1.741 60 ft, but my 2nd gear locked out for a bit and then I just jammed it in and went from there.
All in all. Im very happy with my MPH for the power im making. A new trans and Ill be out there bringing back 10.99 very soon.
Most of you know my setup but here it is anyway.
90 STD hatch gutted.
z6 block w/ vitaras and eagles.
Y7 head stock with aem cam gear. z6 intake manifold and t/b stock.
Cast iron ebay manifold with holset h1c @ 22-23 psi. 3 inch DP. No exhaust.
23x8x13 m&h on lenso's.
Tuned by Xenocron. Car made 280whp but since then has been re tuned on the street.
I *think* Si trans lol. Dont matter anymore its busted. Case cracked up right behind the diff somehow, fluid everywhere. And I still drove it home 70 miles !
Modified by Dr. D-Series at 7:33 PM 3/31/2008
Old Mar 30, 2008 | 11:43 AM
91' LS-VTEC's Avatar
Default Re: Turbo D16 Back from the Track. Broken Trans haha. (Dr. D-Series)
Slip looks pretty good, for a broken tranny. Lets see some pics of the carnage.
Old Mar 30, 2008 | 11:49 AM
If I pick up my new trans tomorrow Ill have some pics up of the trans asap.
Thanks.
Old Mar 30, 2008 | 12:56 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
light as a feather, pulls like a B, its doctor D!! j/k.
good times, your car must be 1900lbs?
Old Mar 30, 2008 | 01:07 PM
Thats what I would guess.
I really have no idea though. I didnt cut any of the car out other than the hood webbing.
Old Mar 30, 2008 | 01:42 PM
13173's Avatar
Default Re: (Dr. D-Series)
with that mph I would guess its making probably 320whp or so. Either way its working well
Old Mar 30, 2008 | 01:57 PM
My last dyno was 279 whp 210 wtq.
Since then I got retuned on the street because I changed my exhaust mani from an ebay tubular to a ebay cast mani.
After the street tune it seemed like I had about 50 more ft lbs, but my high end hp might have been sacrificed from the short runners.
Anyway im still guessing its somewhere near 280.
Thanks dude.
Old Mar 30, 2008 | 11:23 PM
13173's Avatar
Which ebay cast mani is it? Does it have a manufacturer name on it anywhere?
I got a fairly cheap manifold that Im going to replace my old Drag mani with at some point. The Drag mani has did well but its starting to form a small crack that is visible on the outside. I ran across this certain manifold and Im going to give it a try at some point. I feel that it will work fairly well for me.......
Old Mar 31, 2008 | 03:56 AM
The WG hole is on the #1 runner.
They are really cheap. Like 120 or so. But i got mine free from a friend.
Old Mar 31, 2008 | 05:03 AM
SovXietday's Avatar
Pics of carnage!
Dude, you've got anti-lag, start your burnout in gear number 2. Honestly you could probably even light them up in 3, but I doubt your clutch will enjoy that very much.
Good times.
Old Mar 31, 2008 | 05:17 AM
1992Si's Avatar
See I told you over on turboD16 someone would tell you to do the burnout in 2nd or 3rd gear.
rota would do 2nd gear burnout's when he was making 280whp or short shift to 2nd as soon as the clutch hit in 1st.
There was one set of tire marks where 1st gear was about 3ft long and 2nd gear was about 60ft long.
Frank Rehak at the DDS told us the D tranny would only hold 550HP. That was a few years back. I wonder as fatigue set's in that HP number lowers.
I think we have been through the motor mount thing, all your mounts are strong or solid ? you need to keep the driveline from flexing/rotating. Try some solid lower mounts like we had made for rota's car.
I hope your keeping an eye mike's thread too.
Modified by 1992Si at 10:54 AM 3/31/2008
Old Mar 31, 2008 | 07:46 AM
The 3 mounts have energy inserts. The passenger side mount recently ripped off the frame and i rewelded it back on.Been good since.\
I took pics of the damage, ill post up later.
Old Mar 31, 2008 | 07:50 AM
1992Si's Avatar
When I get home tonight, I'll try and remember to post photo of the solid L bracket we had made for rota's car last season. Tranny side.
The drivers side had a 1/4 steel plate from the A/C bracket to the traction bar.
The photo's are on here some where.
Old Mar 31, 2008 | 03:33 PM
It would be sweet if you could find those pics.
Thanks a bunch dude.
BTW pics of trans up in 1st post.
Old Mar 31, 2008 | 03:51 PM
1992Si's Avatar
Here's both mounts out of the car.
Tranny side in the car
Tranny side front/traction bar mount
Drivers side
BTW thanks for the reminder, I'm old, I forget sometimes. Lots of funny stories...
Old Mar 31, 2008 | 04:01 PM
That actually looks pretty easy to make.
Where can I get some of that flat steel plate ?
Thanks a lot.
Old Mar 31, 2008 | 04:44 PM
1992Si's Avatar
Will Dr.
I would have responded sooner but I was on one of the skiing forums.
If you can weld, you should know where to get stock from. Sorry for that.
You may want to call NRG Tech. You should be able to find them in rota92's thread. They could make them for you. Ryan say's there down there some where. NYC area.
Any hardware store should have some metal stock around too.
Old Mar 31, 2008 | 05:07 PM
I know how to mig.
But dont have my own.
I used a flux core, havent had a problem yet with breakage. Im gonna go buy the hardware store and get some.
I have a friend that deals with NRG. I just wouldnt pay for something I could make myself.
Thanks for all the help. Much appreciated.
Old Mar 31, 2008 | 05:12 PM
1992Si's Avatar
Nice to see you can do things for yourself.
Old Apr 1, 2008 | 01:16 PM
Im gonna have to figure something out for the trans side. Im running a cable trans so I dont have the provisions for the stock torque mount.
Shouldnt be too big a deal.
vectorsolid
Aug 27, 2011 05:25 AM
tomu06
Feb 28, 2006 02:31 PM
streetlvlhatch
May 11, 2004 10:49 AM
PM-Performance
May 10, 2004 11:08 AM
streetlvlhatch
May 4, 2004 10:31 PM
