Engine Swap?
Old Mar 30, 2008 | 09:57 AM
Spitz's Avatar
Default Engine Swap?
Hello...new here, and new to Honda so take it easy on me
I have a newly acquired 93 Civic DX.
It has engine problems, 100lb in #4 and 0lb's in #3, so I'm assumming a hole in a piston, possibly broken valves?
Anyway...I have available a motor from a 91 Civic Si ( D16A6 )
Will the motor drop into place of the 93 motor ( D15B7 ) and will the 5sp tranny match?
Thanks for any help.
Old Mar 30, 2008 | 08:36 PM
Spitz's Avatar
Default Re: Engine Swap? (Spitz)
....no one wants to take a stab at this one?
Someone here must know a little bit about this....
Thanks
Old Mar 31, 2008 | 02:05 AM
rd91sib18c5r's Avatar
It will work but you must use all the obd-1 parts, manifold and distributor.
Old Mar 31, 2008 | 05:04 AM
Spitz's Avatar
Default Re: Engine Swap? (rd91sib18c5r)
Great thanks...!
OK, dum b quest. now.... Which one/what is obd-1 ?
Modified by Spitz at 4:16 PM 3/31/2008
Old Mar 31, 2008 | 03:16 PM
Spitz's Avatar
ttt
Old Mar 31, 2008 | 10:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spitz &raquo;</TD></TR><TR><TD CLASS="quote">Great thanks...!
Modified by Spitz at 4:16 PM 3/31/2008</TD></TR></TABLE>
The 91 is obd-0 and the 93 is obd-1.
Old Apr 1, 2008 | 07:12 AM
Spitz's Avatar
Thanks very much for the clarification.
IF it turns out the problem with the 93 is in the valve train.....can I just swap heads??
Thanks again
Old Apr 1, 2008 | 10:20 PM
Yes the head will fit, probably take as much time though.
snowracer69
Sep 6, 2007 05:15 PM
slowassciv33
Nov 3, 2005 02:38 PM
fasterthenmost
11
Nov 1, 2005 07:34 AM
grntrex
Mar 18, 2004 01:09 PM
EL-DOG
Apr 15, 2003 07:08 AM
