Help. Lude won't turn over.
I just finished an auto to manual swap and now my lude won't turn over.
It's not the main relay and it's not the distributor.
The only two things I removed from the bay when I did the swap was the intake manifold to give me clearance when installing the hard line. But we reinstalled that back in and there is spark coming from the plugs.
Anyone have any ideas?
Also there are two plugs disconnected that I can't find where they go to. They are underneath the intake manifold. One is for the knock sensor (which broke) the other is a pink and black/yellow wire plug. Do you think any of these could cause my car not to start up?
So it cranks though? I'd check fuel delivery.
If possible check fuel pressure while cranking.
Also, pull your gas cap and listen if theres compression occuring (after you've turned ignition to accessories a couple times to pressurize tank).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95Lude23 »</TD></TR><TR><TD CLASS="quote">have you checked all of your fuses.</TD></TR></TABLE>
Fuses are all good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz »</TD></TR><TR><TD CLASS="quote">So it cranks though? I'd check fuel delivery.
Also, pull your gas cap and listen if theres compression occuring (after you've turned ignition to accessories a couple times to pressurize tank).</TD></TR></TABLE>
How do I check the fuel pressure?
Fuses are all good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">Heres a no brainer are the plugs in the right firing order?</TD></TR></TABLE>
I never took the head/distributor, or coil out. Only the intake manifold.
With a fuel pressure gauge.
If your car drove before you worked on it, the fuel pressure should work fine.
You probally dont have something connected right.
What do you mean something isn't connected right?
I just checked the fuses. Everything is good. I also Undid the 17mm nut where the fuel line connects to the fuel rail, and fuel came out of it. So I know theres fuel being sent. Is there a certain tq setting for that?
Do any of you know if that pink and black/yellow plug underneath the car would prevent the car from starting?
Try this... It's the big brown plug next to the shifter, it should have plugged into the auto shifter assembly.
Courtesy of h23prelude:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboixtc »</TD></TR><TR><TD CLASS="quote">
Okay, would of been an easy fix if that was it.
Do any of you know if that pink and black/yellow plug underneath the car would prevent the car from starting?</TD></TR></TABLE>
If you can go take a pic of what the wire harness is, Id be glad to go check out what it is on mine. I know I have one plug that isnt connected to anything, but its not the plug you have listed above.
Do you think it could be because my oil pressure switch is disconnected? (the connector below the oil filter) ????
HELP PLEASE. I need my car running by my court date for my stupid tint ticket.
It may as well be the oil switch, might be a saftey cutout on the ECU. If the oil pressure it too low it might keep the engine from turning over so you don't burn it up.
EKSedAndy
Feb 14, 2011 08:07 AM
