car wont pass 3500 rpm???
Old Mar 29, 2008 | 07:48 PM
B18Cej1's Avatar
Default car wont pass 3500 rpm???
i have a b18b1 in my crx and was running a pm6 ecu before today. i switched it to a obd1 p75 with a conversion harness and when i started it i got a cel and the car wouldnt go past 3500 rpm?
any one have a similar experience?
Old Mar 29, 2008 | 09:21 PM
89civichb's Avatar
Default Re: car wont pass 3500 rpm??? (B18Cej1)
Check your codes
HOODLOVER's Avatar
you went from obd0 to obd1?
did you switch to a obd1 dist.?
your gonna need a conv. harness for that to.
Old Mar 29, 2008 | 09:22 PM
89civichb's Avatar
Also a PM6 is OBD-0
Old Mar 29, 2008 | 10:33 PM
B18Cej1's Avatar
Default Re: car wont pass 3500 rpm??? (HOODLOVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOODLOVER &raquo;</TD></TR><TR><TD CLASS="quote">you went from obd0 to obd1?
your gonna need a conv. harness for that to.</TD></TR></TABLE>
I honestly dont know, i didnt do the swap. the motor is obd1 and i was running the obd0 ecu. how can you tell if the distributor is obd0 or obd1?
and im checking my codes tomorrow.
Old Mar 29, 2008 | 10:49 PM
slikzend's Avatar
check the wiring to the dizzy.... i had a the same problem after a swap bout 3 years ago and a pair wires runnin to the dizzy whiched turned out to be the cyl position wires were pinched and were crossing at high engine vibrations hopes this helps
dr_latino999
236
Mar 28, 2020 12:34 AM
SlowB20z
Sep 3, 2012 06:30 PM
efiliated
Jun 6, 2011 04:04 PM
ludesrv
May 12, 2007 08:58 PM
hybridej7
Dec 20, 2004 07:15 AM
