EM1 sounds like a wrx - no misfire or mechanical problems!
Old Mar 29, 2008 | 04:10 PM
ham's Avatar
ham
Default EM1 sounds like a wrx - no misfire or mechanical problems!
I'm having this problem where my b16 sounds / feels like a subaru motor. The first thing I thought was misfire or a weak cylinder, but that is not the case. Here is what I checked so far:
Spark plugs: All 4 look perfect, same condition
Leakdown test: Perfect.... somehow (i was amazed)
Compression: Cyl 2 was 8.3% lower than 1, 3 and 4 (does this throw up a flag?)
Cylinder balance test: All 4 cylinders dropped the same RPM
Injector clip continuity / resistance to ECU
No burning oil, no missing coolant, no vacuum leaks.
Its a totally stock b16 with an intake and a megan header / 2.25" exhaust
According to all tests, all 4 cylinders are running fine. The motor seems perfectly healthy and pulls hard with no smoke, it just has that subaru stumbling / misfire feel between 1 and 3K rpm. Above 3K it smooths out. My girlfriend says my car sounds like an airplane! I am stumped! Anybody have any other ideas?
Old Mar 29, 2008 | 04:18 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: EM1 sounds like a wrx - no misfire or mechanical problems! (ham)
Mine did that when I bought it. It had an OBX header and some kung fu 2.25'' exhaust. I think it's a characteristic sound of the header and exhaust. Mine also felt sluggish at low RPMs....more sluggish than even a B16A should.
Try checking your ignition and cam timing. The culprit for mine was that the ignition timing was too far retarded. I think the T belt was stretched. I just changed the T belt...and have yet to re-check the timing.
Old Mar 29, 2008 | 06:20 PM
ham's Avatar
ham
Default Re: EM1 sounds like a wrx - no misfire or mechanical problems! (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">Mine did that when I bought it. It had an OBX header and some kung fu 2.25'' exhaust. I think it's a characteristic sound of the header and exhaust. Mine also felt sluggish at low RPMs....more sluggish than even a B16A should.
thats funny - i have the cheap ebay megan header and cheap ebay 2.25" exhaust. i havent checked the timing.... i will do that, thanks. it does feel like it has a lack of torque and and sluggish at low rpm.
Old Mar 29, 2008 | 07:12 PM
98civicswapped's Avatar
I had the same problem on my b16 i had the megan 4-1 header and the greddy evo2 exhuast and everybody said it sounded like a wrx
Old Mar 29, 2008 | 07:19 PM
egwhte's Avatar
herra jdm.
no boosheet
Old Mar 30, 2008 | 07:06 AM
ham's Avatar
ham
maybe ill get a decent header and the problem will go away... i dont like the wrx sound!
Old May 3, 2008 | 07:31 AM
ham's Avatar
ham
just wanted to reply to let everybody know i put a stock manifold on and it sounds normal!
Old May 3, 2008 | 07:45 AM
97civic94gsxr's Avatar
well good thing you got that figured out. i have a dc header and a apexi ws2 exhaust and its nice and quiet in regular driving (and doesnt sound like a wrx). you might want a better header like a hytech or hytech replica even, i've never heard people having problems with those.
Old May 4, 2008 | 12:09 AM
Nino_eg6's Avatar
Default Re: EM1 sounds like a wrx - no misfire or mechanical problems! (97civic94gsxr)
my friends em1 sounds the same way he has ractive headers and tanabe catback exhaust.........
Old May 4, 2008 | 12:21 AM
cashkeith's Avatar
the sound you are hearing is from water geting in your distributor most of the time u can just take the cap off and wipe it out and see if anything is rusted
onesick97ek
Sep 30, 2012 03:21 PM
Sport_Injected
Aug 16, 2004 09:06 PM
hondaeg8
Jul 21, 2004 03:32 PM
LSVTEC 91 Civic
25
Jul 12, 2004 01:49 AM
H23ludedude
Oct 21, 2002 10:41 PM
