Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
5 lug conversion necessary for HPDE?
Old Mar 29, 2008 | 02:39 PM
texrex2002's Avatar
Default 5 lug conversion necessary for HPDE?
just curious. I have a 4 lug 92 Si with the re-drilled prelude front disks. I have about 200 whp.
I plan on tracking the car, and am wondering wether the stock 4 lug setup is sufficient. I will be using R compound tires.
I've seen a Neon lose a wheel in front of we and hit the wall because the knuckle broke, and am nervous about that now.
is a 5 luch conversion significantly stronger than the stock 4 lug setup?
I've searched, but there's so much noise I don't know how to filter through it.
Thanks in advance.
Old Mar 29, 2008 | 03:01 PM
I makes it RAIN's Avatar
Default Re: 5 lug conversion necessary for HPDE? (texrex2002)
For what you want to do w/ it, I don't think its necessary.
Old Mar 29, 2008 | 03:08 PM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
Neons are much worse than Hondas about breaking hubs. 4-lug should be fine. If the hubs and bearings haven't been replaced in a while, may want to think about replacement.
Old Mar 29, 2008 | 03:33 PM
granracing's Avatar
If it makes you feel a bit better, most club racing sanctions won't even allow the conversion you're talking about.
Old Mar 29, 2008 | 05:33 PM
Chris F's Avatar
I'm running 4-lug (4x114.3) on my Prelude. No issues here, except wheel selection.
-Chris
Old Mar 29, 2008 | 05:49 PM
roc_sky's Avatar
not necessary, but good to have it.
Old Mar 29, 2008 | 09:16 PM
rebo0t's Avatar
Default Re: 5 lug conversion necessary for HPDE? (roc_sky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roc_sky &raquo;</TD></TR><TR><TD CLASS="quote">not necessary, but good to have it. </TD></TR></TABLE>
x2
Old Mar 29, 2008 | 09:28 PM
Chris F's Avatar
Default Re: 5 lug conversion necessary for HPDE? (rebo0t)
To be clear, I wouldn't even say it's "good to have" from a safety perspective. Mostly just cosmetic and for wheel choices.
Old Mar 30, 2008 | 07:46 AM
jeffy's Avatar
Default Re: 5 lug conversion necessary for HPDE? (Chris F)
just stick with the 4x100. plenty of wheel choices, you wont have to pay a bunch just to get the JDM fantastic 5 lug. an extra lug supporting the load of each wheel seems like it would be helpful but i dont think its even close to necessary. there are plenty of very fast cars with alot more power running 4 lug in every form of racing. i wouldnt worry about it.
Old Mar 30, 2008 | 07:57 AM
nsxtasy's Avatar
H-T Order of Merit
4 lug is fine, on your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texrex2002 &raquo;</TD></TR><TR><TD CLASS="quote">I've seen a Neon lose a wheel in front of we and hit the wall because the knuckle broke</TD></TR></TABLE>
I saw that happen with a Neon SRT4 at Mid-Ohio the end of May 2007. Were you there?
Old Mar 30, 2008 | 10:22 AM
texrex2002's Avatar
Default Re: 5 lug conversion necessary for HPDE? (nsxtasy)
^ no, but I did see that one on a video of a following car. scary...
this was a riced up spec neon type car at a little local event.
Old Mar 31, 2008 | 05:11 AM
dirty19's Avatar
Ridin Dirty in Cali
dont worry about it. 4 lugs are fine.... Im sure there is more to the failure on that neon than just 4 lugs. Freak accidents or mechanical failures just happen sometimes.
Old Apr 2, 2008 | 02:43 PM
xci_ed6's Avatar
Default Re: 5 lug conversion necessary for HPDE? (dirty19)
plus if it was the knuckle that broke it wasn't really fault of the lugs.
Old Apr 3, 2008 | 04:35 PM
kineticgsr's Avatar
Default Re: (granracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granracing &raquo;</TD></TR><TR><TD CLASS="quote">If it makes you feel a bit better, most club racing sanctions won't even allow the conversion you're talking about. </TD></TR></TABLE>
What makes you say that?
Old Apr 3, 2008 | 04:36 PM
kineticgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texrex2002 &raquo;</TD></TR><TR><TD CLASS="quote">just curious. I have a 4 lug 92 Si with the re-drilled prelude front disks. I have about 200 whp.
Thanks in advance.</TD></TR></TABLE>
I have had no issues with my 4 lug Teg over the last 3 years of events..........
Most HC cars are 4 lug as well..... you will not have an issue
Old Apr 3, 2008 | 04:38 PM
Chris F's Avatar
Default Re: (kineticgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kineticgsr &raquo;</TD></TR><TR><TD CLASS="quote">
That change is illegal for SCCA Improved Touring, NASA Honda Challenge H3-H5. I think Dave's point was that SCCA and NASA both think that it's safe enough for wheel-to-wheel racing to keep the 4-lugs on Preludes and Integras, so don't worry about it.
-Chris
Old Apr 4, 2008 | 11:13 AM
rotten's Avatar
is a 5 luch conversion significantly stronger than the stock 4 lug setup?</TD></TR></TABLE>
Nope.
It may be stronger, but not significantly.
There is no real advantage of going with the 5 lug, and all you're doing is adding unsprung weight.
We run 4 lug on the rally cars, and they get stresses that are unlikely to be seen on any road race car. We've never had a hub failure (although we have bent many control arms, trailing arms, radius rods, etc.).
Old Apr 4, 2008 | 11:35 AM
kb58's Avatar
Banned
Default Re: 5 lug conversion necessary for HPDE? (rotten)
I've never heard of an issue at HPDEs I've gone to. They don't even look at the wheels, assuming that the owner has already done his own tech inspection.
Old Apr 4, 2008 | 12:10 PM
texrex2002's Avatar
Default Re: 5 lug conversion necessary for HPDE? (kb58)
ok thanks. I didn't really mean was it required from a tech inspection perspective, but more from a safety and performance perspective.
Old Apr 4, 2008 | 01:00 PM
kb58's Avatar
Banned
Performance? No, 4-lug weighs less. I've never heard of it being a safety issue - however, I have read a couple posts saying that some HPDE organizers don't like "multi-lug" wheels. Those are the ones (I think) that have 8 holes in them for different lug spacing. The concern is that the hub will crack due to the holes being so close together. Don't know how warranted the concern is... anyone actually seen one fail? (Hitting curbs doesn't count!)
Old Apr 4, 2008 | 09:55 PM
Aquafina's Avatar
Not needed. I have a CTR 5-lug on my car and even with OEM ITR pads and the stock 96 DX MC it is more than enough power. If my car had a lot more power then it could be useful. Either way you can do anything (upgrade wise) with 4-lug that you can with 5-lug. I do like it better than the stock brakes though.
Old Apr 5, 2008 | 10:23 AM
pomansouth01's Avatar
Ginger Kid
for the extra weight, its not worth it....I have run full on goodyear slicks before....in a 200 hp coupe with 9" wide slicks....never had a problem with over 200k on the hubs....
DeeSee4K20
Aug 6, 2006 01:31 PM
BlueLude 94
Jan 24, 2006 10:55 PM
mr2slo4u
Oct 14, 2004 08:21 PM
