VHT flameproof coatings?
Old Mar 29, 2008 | 08:11 AM
. a d a m's Avatar
Default VHT flameproof coatings?
Has anyone tried this out? I'm talking about the stuff that comes in a spray paint can, I want to put it on the exhaust side of my turbo.
Old Mar 29, 2008 | 08:29 AM
non-VTEC's Avatar
Default Re: VHT flameproof coatings? (. a d a m)
the stuff works well as long as the surface is prepped well. clean of oil and rust. it holds up to heat pretty good.
Old Mar 29, 2008 | 08:30 AM
hotimportcrx's Avatar
Default Re: VHT flameproof coatings? (non-VTEC)
I've used it on a turbo manifold and it held up pretty good.
Old Mar 29, 2008 | 08:42 AM
. a d a m's Avatar
Alright cool, I guess I'll give it a shot then.
Old Mar 29, 2008 | 11:49 AM
Joseph Davis's Avatar
What is the price on the stuff?
Old Mar 29, 2008 | 03:26 PM
Crx Jimmy's Avatar
Default Re: VHT flameproof coatings? (Joseph Davis)
$7 or so a can
Old Mar 29, 2008 | 03:34 PM
swapit's Avatar
Default Re: VHT flameproof coatings? (Crx Jimmy)
i used it on my exhaust housing,did the whole baking thing and made the house stink...lol but seems to be holding up good.
Old Mar 29, 2008 | 03:47 PM
stealthmode62's Avatar
Default Re: VHT flameproof coatings? (swapit)
I've been looking for something to do my manifold with, but I've always been a skeptic of spray on auto zone ish. Post pics if you've got them, and how long it's held up.
Oh yeah, Joseph Davis taught me everything I know.
Old Mar 29, 2008 | 04:10 PM
non-VTEC's Avatar
works good from keeping it from rusting so fast.......not so much for keeping the heat down.
Old Mar 29, 2008 | 07:36 PM
Minor Threat's Avatar
It holds up, but it doesn't do much other than look pretty.
It is a good substitute for the silicone sealer you get with exhaust wrap kits though.
Old Mar 29, 2008 | 10:23 PM
Default Re: VHT flameproof coatings? (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">Oh yeah, Joseph Davis taught me everything I know. </TD></TR></TABLE>
There goes most of my credability.
Easy come easy go.
Old Mar 30, 2008 | 09:47 AM
nowtype's Avatar
Do a search for exhaust coatings and rmcdaniels.
Edit: Nevermind, here it is https://honda-tech.com/zerothread?id=1608324
Old Mar 30, 2008 | 07:02 PM
Cole D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapit &raquo;</TD></TR><TR><TD CLASS="quote">i used it on my exhaust housing,did the whole baking thing and made the house stink...lol but seems to be holding up good.</TD></TR></TABLE>
please tell me you didn't use the same oven you cook food in
Old Mar 31, 2008 | 01:32 AM
AspectIndustries's Avatar
Default Re: VHT flameproof coatings? (Cole D)
Im always curious. I use them on exhaust I finished up, around the welds, etc. (mild steel) They seem to hold up fine, Im curious on how well it holds up on hotter surfaces?
Old Mar 31, 2008 | 07:20 AM
B20luda's Avatar
Default Re: VHT flameproof coatings? (AspectIndustries)
I have used it on my manifold and turbo a couple setups ago...and it held up great i was really surprized, i also use it to paint my heat wrap, the high heat spray for the wrap doesn't hold up for ****... but the VHT looks good!!
Old Mar 31, 2008 | 09:08 AM
swapit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cole D &raquo;</TD></TR><TR><TD CLASS="quote">
please tell me you didn't use the same oven you cook food in </TD></TR></TABLE>ya in my old apartment stove lol
Old Mar 31, 2008 | 12:14 PM
rudebwoy's Avatar
3+ months of hard hot driving. cured it on the car via VHT instruction.
Old Mar 31, 2008 | 12:42 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Re: VHT flameproof coatings? (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">
3+ months of hard hot driving. cured it on the car via VHT instruction.</TD></TR></TABLE>
Woah that looks good! Im considering doing what roger did on his manifold with the DIY, but i dont have access to my sandblaster anymore- does this flameproof coating have any thermal properties, or is it purely cosmetic?
thanks!
Old Mar 31, 2008 | 01:17 PM
rudebwoy's Avatar
it seems to have some, before coated it took a long time to cool down, the manifold is cooled to touch after 10 minutes.
plus I used to burn through the dei heat sheild under the before the coating, but now it does not burn anymore.
one thing about it, I wish I could get a jet hot coat, but for now this is good.
Old Mar 31, 2008 | 03:55 PM
Default Re: (rudebwoy)
I'm dissapointed in you Leroy. Where's the black? Bright colors make me cringe.
Old Apr 1, 2008 | 05:44 AM
rudebwoy's Avatar
Default Re: (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> I'm dissapointed in you Leroy. Where's the black? Bright colors make me cringe. </TD></TR></TABLE>
I am slowly getting there, I am getting tired of all the bright stuff myself, redoing my setup soon, RLD fab manifold keeps cracking and he won't fix it because I got it rewelded by somone else the first time it did, for $1250 you would expect more. so whenever I get a new manifold, I will stealth everything.
Old Apr 1, 2008 | 06:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">I am slowly getting there, I am getting tired of all the bright stuff myself, redoing my setup soon, RLD fab manifold keeps cracking and he won't fix it because I got it rewelded by somone else the first time it did, for $1250 you would expect more. so whenever I get a new manifold, I will stealth everything.</TD></TR></TABLE>
Hit up Craig at Tunertoys, he sells what you have for around half and the quality is top notch. Goforth has bought 2-3 and I was impressed, reminds me of the old FR hand-welds or the current run of Peakboost units.
Old Apr 1, 2008 | 09:17 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> I've been looking for something to do my manifold with, but I've always been a skeptic of spray on auto zone ish. Post pics if you've got them, and how long it's held up.</TD></TR></TABLE>
If you're looking, then check out Caswell Plating's coatings. The 12oz. will be able to do your manifold like 6 times or so. Then just buy a disposable air brush gun at Harbor Freight for like $20. I've been using this coating and it's wonderful.....as in after driving on the highway for an hour I can immediately get out and hold my finger 1/8-1/4" away from the manifold and get bored before my finger is too hot.
Since I got the new manifold, this has lasted me since about August/September-ish '07. This summer it could probably stand to come off and be re-coated. But for about $12.50 per coating you won't find anything as good for that cheap.
Click Here
See above again For awhile it will have a slight gloss appearance to it, but it eventually will change to more of a flat black. I haven't tried their CermaBlue coating though....just the black stain coating. No baking required is very convenient.
Modified by Dunc at 1:30 PM 4/1/2008
djuosnteisn
Welding / Fabrication
25
May 20, 2013 11:41 AM
rmcdaniels
Sep 19, 2011 03:33 AM
pleej
Jun 3, 2009 06:00 AM
Lucky_Smurf
Jun 16, 2005 11:38 AM
greyzone
Dec 14, 2004 12:54 PM
