Suspension & Brakes Theory, alignment, spring rates....
Is this normal for camber issues?????
Old Mar 29, 2008 | 05:45 AM
mikeycivic's Avatar
Default Is this normal for camber issues?????
As some may know I have posted about some issues Im having with my suspension. GC/Illuminas I adjusted the height in the front to make both sides even. It appears that the camber is more negative on the driver side than the passenger. Is this normal? I have not been in an accident and dont know why it would be so different between both sides. Do I need a camber kit to give me the same negative camber on the passenger side?
Old Mar 29, 2008 | 07:54 AM
bmoua's Avatar
has a alignment been done?
Old Mar 29, 2008 | 09:11 AM
mikeycivic's Avatar
Default Re: (bmoua)
no not yet.
Old Mar 29, 2008 | 08:10 PM
supracrx's Avatar
how do you know if alignment is that far away from one another? what is the camber right now? is a lot different from side to side?
im on coilovers and driver side i'm at -3.0 and pass is at -3.2 camber..the pass side is little lower, very slightly that u can't see in person but by the machine, the camber shows it is.
Old Mar 30, 2008 | 05:41 AM
mikeycivic's Avatar
Default Re: (supracrx)
because you can see it and feel it. I will try and get pix today
Old Mar 30, 2008 | 08:54 AM
PIC Performance's Avatar
Default Re: Is this normal for camber issues????? (mikeycivic)
There's plenty of reasons why camber might differ from side to side, and honestly none of them are worth discussing until the car is properly aligned on an alignment rack by someone who knows what they are doing. Eye-ball alignments are like butt-dyno tests.
Old Mar 31, 2008 | 04:00 PM
Tyson's Avatar
chamber changes with ride height.
if you had to adjust the suspension travel in order to get the ride height even, then camber is going to be different too.
there of course is many other reasons why things, not just camber, are unequal side to side. naturally weight is not equal. and bushings could have worn unequally. and of course bent parts from daily use or hitting potholes and stuff.
theres no single answer to this, at least not without more information.
you need an alignment anyway. so get that done first and asap.
TegGsr4dr
Jul 10, 2007 09:35 AM
kndaqikEG
Feb 20, 2005 05:42 PM
Kyles ej1
26
Nov 19, 2004 06:09 AM
jdmkrazie
Nov 4, 2004 03:38 AM
AcCO12D95
Jun 12, 2004 10:48 AM
