Honda S2000 Honda S2000
How to change rotors?
Old Mar 28, 2008 | 03:05 PM
veilsides2000's Avatar
Default How to change rotors?
Okay im changing my rotors on a 2002 honda s2000.
Question is that there are two little screws that go through the rotor.
Do those need to come out?
Its hard to get them out, any insight or tips on how to get them out before i start banging away?
Old Mar 28, 2008 | 03:12 PM
Default Re: How to change rotors? (veilsides2000)
bump
Old Mar 28, 2008 | 03:34 PM
GRAF-FITI's Avatar
* B A N N E D *
*helpful post from graf-fiti*
you can just drill them out...their only purpose is to hold the rotors in place during the vehicle assembly process
they are NOT required upon replacement
Old Mar 28, 2008 | 03:56 PM
5 Skware's Avatar
I missed the boat
Default Re: How to change rotors? (GRAF-FITI)
You can also just use a impact screwdriver to get them out. Best / easiest way IMO.
Old Mar 28, 2008 | 05:04 PM
Agent Zero's Avatar
Default Re: How to change rotors? (5 Skware)
I just changed mine. I used a screwdriver and a hammer. As I tried to turn the screw driver I hit the end of it with a hammer. It worked great. And Graffiti is right, they are not needed. But it makes it easier IMO to reassemble everything. GL
Old Mar 31, 2008 | 10:30 AM
p nut's Avatar
I don't think it makes it easier to put it back together. Get rid of those things. I used an impact driver to get them out.
Old Mar 31, 2008 | 11:55 AM
Techno Tonis's Avatar
Default Re: (p nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p nut &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it makes it easier to put it back together. Get rid of those things. I used an impact driver to get them out.</TD></TR></TABLE>
If they are really stuck, use an impact or drill... if not, use a hammer and screwdriver.
Old Mar 31, 2008 | 04:33 PM
JDM knowledge's Avatar
Default Re: (Techno Tonis)
use an impact gun with a 1/4 standard attached with a phillips bit in it. Knock it with something to loosen the screws first and then get it out. Dont strip it! You dont need them but it makes putting them back on a whole lot easier cause the damn thing slides around.
Ninja Side note: When working on a 95 E class Benz these are necessary since Germans thought i was needed. If you have ever worked on a Benz it sucks doing suspension and brake work.
Old Apr 1, 2008 | 05:23 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (JDM knowledge)
as a lot of people have said, use the impact driver... mine were soooo tight on my GSR, that I had to use the impact to tighten them more to loosen them... sounds strange but it worked... good luck
Old Apr 1, 2008 | 05:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">use an impact gun with a 1/4 standard attached with a phillips bit in it. Knock it with something to loosen the screws first and then get it out. Dont strip it! You dont need them but it makes putting them back on a whole lot easier cause the damn thing slides around.
Ninja Side note: When working on a 95 E class Benz these are necessary since Germans thought i was needed. If you have ever worked on a Benz it sucks doing suspension and brake work. </TD></TR></TABLE>
Good point, forgot about that. You will need at least 1 screw to put them back on.... otherwise it's a bitch.
Old Apr 2, 2008 | 01:24 AM
dagle's Avatar
yeah i just smashed a screwdriver before turning and it worked fine, did the same on both sides. oh and when doing brake work, make sure its cooled.. my stupidity costed a nice chunk of skin from my fore arm. lol
eric416
Dec 2, 2009 02:55 PM
Aqualungs
Sep 15, 2009 04:53 PM
93CamaroLT1
May 31, 2006 05:49 PM
MadCityLude
Nov 26, 2005 05:42 PM
Flux
Apr 13, 2003 11:05 AM
