installing a master cyclinder on a 96 ex
Old Mar 28, 2008 | 12:25 PM
v8 integra's Avatar
Default installing a master cyclinder on a 96 ex
i was just wondering if i needed to grease any parts of the cylinder before i install it. i searched but i couldnt find anything about it..i was asking because on the pedal side of the firewall it looks like theres alot of grease lobbed on there..thanks in advance!!
Old Mar 28, 2008 | 12:42 PM
95jeremie's Avatar
Default Re: installing a master cyclinder on a 96 ex (v8 integra)
bench bleed and install
Old Mar 28, 2008 | 12:43 PM
tazeat's Avatar
and just for kicks if you need it:
Old Mar 28, 2008 | 12:49 PM
v8 integra's Avatar
Default Re: installing a master cyclinder on a 96 ex (tazeat)
thank you so much for the GREAT help!!!!!!!!!!!!!!!!!
Old Mar 28, 2008 | 04:37 PM
v8 integra's Avatar
k i jus finished install my new master clutch cylinder...tried bleeding it untill i found out my slave cylinder was leaking...g00oo0sh!!...anyways..the instuctions helped..it was cakeee..thanks alot again!
Old Mar 28, 2008 | 04:45 PM
JeffBro's Avatar
Yeah you usually replace both the master and slave cylinder together. Whatever caused one to fail could just as likely cause both to fail in a liquid system connected together.
Old Mar 28, 2008 | 05:04 PM
v8 integra's Avatar
Default Re: installing a master cyclinder on a 96 ex (JeffBro)
ha..does that usually happen??? both of them fail at the same time? i never knew that...well thats some good info..thanks!
Jon Petersen
Dec 23, 2018 02:47 AM
niceprelude
Nov 1, 2010 06:16 AM
GSR-TRBO-DA
Nov 26, 2007 08:19 AM
raynaud
Aug 1, 2004 01:52 PM
Audipwr1
Apr 12, 2002 11:22 AM
