d16z6 tranny rebuild
Old Mar 27, 2008 | 10:56 PM
tambara's Avatar
Default d16z6 tranny rebuild
I was wondering what sort of parts would I need to rebuild my transmission? I was hoping for performance parts but the only thing I was able to pull up is the clutch and flywheel. Are there any other parts I would need to rebuild the transmission?
Old Mar 28, 2008 | 10:43 AM
jdmtunerchick's Avatar
Default Re: d16z6 tranny rebuild (tambara)
Well why are you rebuilding it? Is your shift fork bent/broke or do you just want to change your gear ratio? And if so longer or shorter?
Old Mar 28, 2008 | 10:49 AM
tambara's Avatar
Default Re: d16z6 tranny rebuild (jdmtunerchick)
my transmission is a bit loose. not only that I wanna get a performance into it. I wanna start with the transmission and then with the engine. I wanna acceleration faster and get the most performance.
Luserkid's Avatar
Brian long time man.
The guys to ask is Bense, or Mista Bone. Those guys are D series trans gods (at least in my eyes). Theres alot of different little things you could do with the trans. Whats your goals for the trans?
Old Mar 28, 2008 | 10:54 AM
tambara's Avatar
Default Re: d16z6 tranny rebuild (Luserkid)
hey man, yea it has been awhile. the car still runs well, since then my dad replaced the engine with a zc engine but left the same transmission that you put in for me. I think the tranny is a bit loose since i first got it. What I want from the transmission is the most performance what ever that is. I just want a good stable tranmission.
Old Mar 28, 2008 | 12:25 PM
Luserkid's Avatar
By loose do you mean the shifter feel? It could be the bushings? If you want a stiffer shifter feel then you could get some ES bushings that helps it alot.
As for performance:
You do know that the shorter the gears the higher the RPM at the lower speed right?
Say your at 4500rpm @ 80mph, that could easily turn into 5500rpm @ 80 mph but quicker acceleration. What i would probably do would be 1, 2, 3 from a EX/SI 4th from a DX and 5th from a VX. That way you would get good acceleration with a good cruising gas saver.
Old Mar 29, 2008 | 10:08 AM
"Say your at 4500rpm @ 80mph, that could easily turn into 5500rpm @ 80 mph but quicker acceleration. What i would probably do would be 1, 2, 3 from a EX/SI 4th from a DX and 5th from a VX. That way you would get good acceleration with a good cruising gas saver. "
I agree with him!! My friend and i rebuilt my tranny with a short final dive and i hate taking her on the interstate! Caz im allways in V-tec!! But i dont like doing the speed limit.. i just wana go fast! and im sure u do to!
Old Mar 29, 2008 | 10:21 AM
tambara's Avatar
lol thanks for the input
2x0
Transmission & Drivetrain
11
Aug 18, 2021 09:53 AM
Korey Klausing
Nov 19, 2016 06:36 AM
DeadPixel
15
Dec 20, 2008 07:12 PM
David.Dgn
Apr 13, 2008 07:05 AM
