WHAT AXLES FOR CABLE TRANS IN EG SOL ????
Old Mar 27, 2008 | 08:29 PM
mycivicislower's Avatar
Default WHAT AXLES FOR CABLE TRANS IN EG SOL ????
IM PLANNING ON RUNNING B16A WITH CABLE TRANS IN 93 SOL WITH HASPORT CONVERSION,BUT I NEED TO KNOW WHAT AXLES WILL FIT? IS THERE A DIFFERENCE BETWEEN CABLE AND HYDRO AXLES ? SAY DEL SOL VTEC AXLES OR 99-00 SI AXLES? ANYTHING TO HELP POINT ME IN THE RIGHT DIRECTION ( BESIDES BUYING A HYDRO TRANNY AND I KNOW THIS IS A BACKWARDS SWAP) WILL BE GREATLY APPRECIATED !
Old Mar 27, 2008 | 08:39 PM
crazyguy's Avatar
Default Re: WHAT AXLES FOR CABLE TRANS IN EG SOL ???? (mycivicislower)
cable or hydro axles dont matter. it depends on what kind of intermediate axle u are running. if u are running da integra hals axle. u will need da integra axles. which have both male ends. and if u are running with dc integra half axles.. u will need 94-01, 94-97 del sol vetc axles, 99-00 civic si acles.
Old Mar 27, 2008 | 08:58 PM
SirRevvs's Avatar
Default Re: WHAT AXLES FOR CABLE TRANS IN EG SOL ???? (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">cable or hydro axles dont matter. it depends on what kind of intermediate axle u are running. if u are running da integra hals axle. u will need da integra axles. which have both male ends. and if u are running with dc integra half axles.. u will need 94-01, 94-97 del sol vetc axles, 99-00 civic si acles.</TD></TR></TABLE>
Correct DA or DC axles will work it depends on the int shaft you're using. Also you have to use a DA driver side axle seal for 90-93 int shaft and a DC driver side axle seal for 94-00 int. shaft. Pass. side axle seals are the same.
Old Mar 27, 2008 | 09:24 PM
thank you very much !
speeddave
Sep 4, 2008 02:28 PM
GiT LaO'd
Jan 17, 2008 06:08 PM
b16a3delsol
Sep 3, 2007 05:48 AM
civic_crazy02
Jun 10, 2006 04:48 PM
