Did 1992 civic CX's come with a front sway bar?
Climbed under my civic for the 1st time today and noticed it had neither front nor rear sway bars - i know rears only came on EXs but what about fronts?
I replaced the lower control arms today and the old ones had no holes for the links, the new ones do but I don;t see what the bar would mount to the frame?
Anyone have an underbody suspension picture that illustrates where the sway bar to frame mount bushing go?
Thanks.
Thanks.
the endlinks bolts up to the front LCA like so....
Then the d-bracket bolts up next to those three 19mm bolts for ur front LCA. One stud sticks out and there is a hole for the otherside of the d-bracket. like so...
This is the hardware you need. I found these in my bag of left over bolts and nuts. 2 12mm bolts, two 13mm nuts, and two washers for the nuts.
any more questions...
https://honda-tech.com/zerothread?id=879554
JMelt4
18
Apr 30, 2007 07:43 PM
EJ2-Fluffy
Dec 8, 2006 02:17 PM
