HELP asap! how'd you guys get the bolt in for the drag manifolds?
Old Jul 9, 2002 | 04:04 PM
ceemarun's Avatar
Default HELP asap! how'd you guys get the bolt in for the drag manifolds?
all the bolts go into the manifold fine, but the bottom center one is really close to the tubes on the manifold, and i cant get the bolt through to bolt down the manifold. what did you guys do?
Old Jul 9, 2002 | 04:10 PM
len's Avatar
len
Default Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (ceemarun)
You unbolt everything. Then you act like you are putting the manifold on but before the stud goes through the manifold completely, you place the nut and hold it there. Then slightly push and thread and you will start to thread the nut on the stud. Keep moving closer and thread the nut at the same time.
Assuming you removed the stud from the far left and placed it in the middle.
Good Luck and play with it a little you'll know what I'm trying to describe.
Old Jul 9, 2002 | 04:19 PM
GSRgrrl's Avatar
I actually shaved the bolt's head a little to get it to fit.
Old Jul 9, 2002 | 04:41 PM
ceemarun's Avatar
Default Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (iloveracing)
but the one that i cannot seem to get going isnt the two studs on each side. im talking about the dead center one on the bottom. that requires a bolt, and everything is closed here so i cant go and find a matching nut and stud. its just that the bolt itself cant get into the hole cuz the tubes are in the way.
b18bvudoo's Avatar
New User
Default Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (GSRgrrl)
thats what i had to do w/ my fmax mani....3 of the top ones
Old Jul 9, 2002 | 05:13 PM
Mr. Softee's Avatar
Default Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (b18bvudoo)
i just slipped it in?
Old Jul 9, 2002 | 05:31 PM
dustin's Avatar
Default Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (94goldjungsr)
the old heads had all studs + nuts
the new heads have 2 outer studs and the rest are bolts
If I were you, I'd replace all those dumb bolts with studs, makes things 10x easier
Old Jul 9, 2002 | 05:56 PM
ceemarun's Avatar
Default Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (dustin)
i guess i'll pick some up tomorrow. do you know what size the studs should be? (? threads/in), etc? thanks.
Old Jul 9, 2002 | 05:57 PM
rjardy's Avatar
perhaps a latent meaning?
ROB
BlueShadow
Jun 18, 2005 07:02 PM
DENCIO
Jul 21, 2004 07:16 PM
Stu
Jan 15, 2004 01:19 PM
R-1303
Jun 11, 2002 06:01 AM
GrandMarkie
May 17, 2002 12:53 PM
