2000 bb6 waterpump and crankshaft pulley
Old Mar 27, 2008 | 09:57 AM
2000h22a's Avatar
Default 2000 bb6 waterpump and crankshaft pulley
is the crankshaft pulley bolt left hand threaded?? im changing my water pump and i do not have the pulley tool and have to do the job without it
please help im stuck trying to get it off and need some ideas
any help is greatly appreciated
Old Mar 27, 2008 | 09:59 AM
117's Avatar
117
The crank pulley bolt is RH threaded. Turn it CCW to remove.
You'll either need a tool to hold the crank pulley in place and a long breaker bar, or a very strong impact wrench.
I've done 20+ H22 timing belts, and my trusty Honda crank pulley holder and breaker bar have never let me down.
Old Mar 27, 2008 | 10:31 AM
esedulerp5tenin's Avatar
Default Re: (117)
from experience, save yourself the giant headaches and just buy the $25 tool.
i tried to take the crank pulley off w/o the tool for literally 2 weeks, then i finally broke down about bought the tool, came off in literally 5 minutes.
Old Mar 28, 2008 | 03:11 AM
dave007z's Avatar
Default Re: (117)
Are the 80's series Honda Civics also right hand threads on the crankshaft pulley bolts? Thanks
Old Mar 28, 2008 | 03:28 AM
no1knows908's Avatar
Default Re: (dave007z)
Tried a cheap impact, didn't work... Tried a beastly MAC impact, didn't work... Finally got my hands on a home made pulley holder, had to put all my weight on the breaker bar and jump three times then finally broke it loose...
Old Mar 28, 2008 | 12:13 PM
dre2day's Avatar
Default Re: (no1knows908)
anyone hear about cranking the car to get the crank bolt off?
Old Mar 28, 2008 | 12:57 PM
117's Avatar
117
Since the engine rotates CCW, you'd just be tightening the bolt if you tried cranking the engine with a wrench on the bolt.
Old Mar 28, 2008 | 12:58 PM
vlang29's Avatar
Default Re: (dre2day)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre2day &raquo;</TD></TR><TR><TD CLASS="quote">anyone hear about cranking the car to get the crank bolt off?</TD></TR></TABLE>
it WOULD work.. IF the engine turned clockwise instead of counter-clockwise.. so cranking the engine with the bolt held will just tighten the bolt even more
Old Mar 28, 2008 | 10:39 PM
gstrudler's Avatar
Default Re: (vlang29)
Definitely use the pulley tool; I also discovered using a 20" long 1/2"-drive extension on the 19mm socket allows you to get your breaker bar outside the car and really torque on it. Came off pretty quick after trying relentlessly without the extension and struggling under the car. But yet, the pulley bolt is a pita
Powered By Garrett
19
Jul 20, 2008 05:17 PM
B!^A@
Nov 21, 2006 10:04 AM
grngsr01
Oct 23, 2005 05:47 AM
EgSalad
22
Oct 7, 2005 05:03 PM
TrueZen
Feb 27, 2004 07:42 AM
