Inlinefour Head Gasket, Does it really lower the compression of b18c1 dramatically?
Old Jul 9, 2002 | 02:38 PM
IMSTOCK's Avatar
Default Inlinefour Head Gasket, Does it really lower the compression of b18c1 dramatically?
Inlinefour Head Gasket, Does it really lower the compression of b18c1 dramatically? Does anybody here have any experiance with it? Is it a long lasting gasket, and does it hold up against a 15 lbs of boost set up?
Old Jul 9, 2002 | 02:41 PM
blufke's Avatar
Default Re: Inlinefour Head Gasket, Does it really lower the compression of b18c1 dramatically? (IMSTOCK)
yes it does drop it quite a bit. i.e. HKS decompression gasket(2.6mm or 3mm not sure) puts a b16a around 9:1, perhaps lower i think.
Old Jul 9, 2002 | 02:47 PM
jinxproof99's Avatar
New User
inlinepro sells a headgasket for the b18c1. puts it at around 9.2:1. works very well. i'm using one on my 10 second street car. definatly holds over 450 horsepower to the wheels.
Old Jul 9, 2002 | 04:52 PM
DR. ON POINT's Avatar
Banned
Default Re: Inlinefour Head Gasket, Does it really lower the compression of b18c1 dramatically? (jinxproof9
InlinePro is the best
Old Jul 9, 2002 | 05:12 PM
ITRinEJ1's Avatar
i have a used one for sale for b18c1 if anyone is interested
Old Jul 9, 2002 | 07:09 PM
CalvitoSol's Avatar
will i not be needing lower comp pistons if i get the gasket then?
Old Jul 9, 2002 | 07:44 PM
Banned
no, ur stock pistons are fine with a InlinePro headgasket
Old Jul 9, 2002 | 07:50 PM
Adi Radoncic's Avatar
On Fire!
Like Jinxproof sead inlinepro sells one thats 2.7mm thick and lt works, I'm also using one on my gsr with all stock internals pushing almost 14psi..
I think jinxproof had his running 22psi at the track with all stock internals and race gas....
Inlinepro is the shhhhhiet!!!
Great products..
Adi
Old Jul 9, 2002 | 07:57 PM
CalvitoSol's Avatar
ttt
[Modified by theory48, 11:54 AM 11/16/2002]
Old Jul 9, 2002 | 08:16 PM
CalvitoSol's Avatar
is there a big difference in realiability when lets say, i run 7-8lbs w/ inlinepro gasket and w/o? thanx
Old Jul 10, 2002 | 06:44 AM
Banned
ur compression will be lower so u will be able to run higher boost
and I believe someone is underestimating the power of a headgaske, stock pistons are fine.
Old Jul 10, 2002 | 11:27 AM
CalvitoSol's Avatar
how much, should i expect to pay for a gasket, arp studs, plus labor?
Old Jul 10, 2002 | 01:50 PM
Houston Hatchback's Avatar
where can i get his head gasket i really wanna drop my compression down alot b/c im have about 12:3 piston in my car rite now and i wanna go turbo soon but i dont feel like buying some more piston..
Old Jul 10, 2002 | 02:09 PM
On Fire!
Inlinepro headgasket: $300 +shipping
Arp Headstuds: $120 shipped
Timing Belt: $75 at the dealer
Waterpump: $65 at the dealer
Labor: $500 maybe more and maybe less
The reason I listed the waterpump and timing belt is because if you are doing all of that work already you might as well replace them as preventative maintenance and not have to worry about them later on down the road....
Adi
Old Jul 10, 2002 | 02:11 PM
On Fire!
Default Re: Inlinefour Head Gasket, Does it really lower the compression of b18c1 dramatically? (Houston Ha
Two headgaskets might work but I wouldn't try it you really need pistons because your compression is way too high in the begining to work with....
Adi
Old Jul 10, 2002 | 02:23 PM
CalvitoSol's Avatar
can someone give me the breakdown on how compression works? i don't quite understand it. and just gasket and labor runs that much? isn't it better then to just save up and wait for a rebuild with strong aftermarket parts?
Old Jul 12, 2002 | 01:12 PM
New User
until they melt away...dosnt meen his stock CAST pistons can survive, and they wont for long..
i have run 12 lbs of boost on stock pistons/rods/sleeves(b18c1 motor) on 93 octane gas with an inlinepro headgasket for over a year and never melted anything. i have seen someone do it for 3 years now. same motor.
maybe you just need a new tuner.
Old Jul 12, 2002 | 02:01 PM
IMSTOCK's Avatar
So a b18c1 + gasket + garett T60-1 = High 11's ?
Old Jul 12, 2002 | 05:51 PM
Banned
its not a math equation, u have to have the right ****, good injectors, and tune it
Old Jul 14, 2002 | 03:24 PM
IMSTOCK's Avatar
HEY OLD DIRTY BASTARD,
i know it takes the right **** to go with it. I was hoping you would realize i would also include that automatically. But hey im pretty sure it should make for a good set up. THANX HONDA TECH
silentdaredevil2
Nov 24, 2005 12:29 PM
vtekthis
Nov 2, 2004 07:17 PM
bodydropranger
Dec 27, 2002 07:01 AM
