Lug nut/stud problem.
Old Mar 26, 2008 | 05:25 PM
Maui Built's Avatar
Default Lug nut/stud problem.
I was taking my lug nuts off to change my brakes and i'm guessing the ribs on the lug stud stripped so now everytime i turn the lug nut, the wheel stud spins with it.
How do i get/brake this off? Please help
Thanks in advance
Old Mar 26, 2008 | 05:29 PM
crazyguy's Avatar
Default Re: Lug nut/stud problem. (Maui Built)
Old Mar 26, 2008 | 05:30 PM
Maui Built's Avatar
Default Re: Lug nut/stud problem. (crazyguy)
the rim is still on the car.
Old Mar 26, 2008 | 06:42 PM
hard_boiled_EG's Avatar
i had a problem like that...i used a dremel...with the longest bit home depot had that was for metal...it's not a cut-off wheel, it's more like a dirll bit, it's made to dirll into then you can move it side to side, ex: to cut out the holes in your finder for the jdm side markers...hope that helps
Old Mar 26, 2008 | 06:46 PM
93preludeh22's Avatar
might be able to cut off the back of the wheel stud and pull the whole thing through with your rim? using a grinder maybe?
Worst case, put the other lugs back on and drive it to a shop
Anthony
Old Mar 26, 2008 | 09:47 PM
Maui Built's Avatar
thanks everyone, i used a dremel to get it off, cut the lug nut in half.
prelude_93vtec
May 8, 2008 08:22 PM
cbstudd77
Nov 28, 2006 09:45 PM
kyteggy
Feb 5, 2006 01:39 PM
ArchAngel Sabastian
Jul 19, 2003 09:33 PM
TurboLude97
Feb 2, 2003 01:56 PM
