Can't run CEL code. EG Hatch with GSR motor
Old Mar 26, 2008 | 05:11 PM
dc2doi's Avatar
Default Can't run CEL code. EG Hatch with GSR motor
Got a gsr motor in the eg hatch. OBD1.
Now got a check engine light on. I can't seem
to run the check engine light. I connected the wires on the blue
connector. Nothing is showing but instead the SRS light is blinking.
Any idea what could cause this?
Old Mar 26, 2008 | 05:31 PM
crazyguy's Avatar
Default Re: Can't run CEL code. EG Hatch with GSR motor (dc2doi)
blue? i thought it is grey
https://honda-tech.com/zerothread/1901557
Old Mar 26, 2008 | 06:21 PM
dc2doi's Avatar
It might have been grey. Eitherway it was night and that was the only connector there was near the ecu that wasn't connected.
Old Mar 26, 2008 | 07:29 PM
lv6l's Avatar
Try plugging the paper clip in the butt side of the harness. The side where you can actually see the metal wrapping on the wires.
Old Apr 19, 2008 | 12:20 PM
davenport517's Avatar
Default Re: (lv6l)
just stick a bit of wire in the d4 pin (should be brown) and run it to an earth, i couldnt check mine with my pld ecu but then i switched to a p30 and its fine
SINBAD
Mar 1, 2010 08:18 PM
cor4ey
Dec 20, 2008 12:42 PM
allmotorEG-SI
Jul 20, 2004 09:51 PM
c8r9x
Jul 6, 2004 10:24 AM
Bassicfun
Jul 28, 2003 06:00 PM
