87 Si won't start...
Old Jul 9, 2002 | 12:46 PM
B_CRUZ!'s Avatar
Default 87 Si won't start...
My 1987 CRX si won't start. It started yesterday when i accidently left the phone charger in the cigarette lighter outlet. i noticed it after work. i tried starting it but it wouldn't. It would crank but it won't stay on. I called a mechanic freind of mines and he checked the cap and rotor and said it was bad. I replaced it today and it still won't start. I still hear the fuel pump so it can't be that. Do you think the coil is messed up?
What do you suggest I look at?
Old Jul 9, 2002 | 01:48 PM
Ausmith's Avatar
Default Re: 87 Si won't start... (B_Cruz)
Check all of the fuses that are under the hood.
Make sure you put the spark plug wires back on right.
Make sure you have gas in the tank and prime the pump a few times.
Old Jul 9, 2002 | 02:03 PM
Chiovnidca's Avatar
Does it have spark?
Old Jul 9, 2002 | 03:36 PM
B_CRUZ!'s Avatar
Default Re: 87 Si won't start... (Chiovnidca)
yeah. and i hear the fuel pump pumping... i am stumped... no codes either...
Old Jul 9, 2002 | 06:21 PM
Chiovnidca's Avatar
Is it flooded?
Old Jul 9, 2002 | 11:46 PM
ElephantSuprise's Avatar
might have washed out the rings, unplug the fuel injectors and crank til it starts, otherwise if no spark sheck the ignitor
Old Jul 10, 2002 | 07:35 AM
B_CRUZ!'s Avatar
Default Re: 87 Si won't start... (ElephantSuprise)
got it towed last night and the driver says it might be a glogged fuel filter... thanks for the info... i need my beater running soon.
Old Jul 10, 2002 | 08:13 AM
Spade's Avatar
I would suggest fuel filter.....sorry I didn't see this yesterday.
wanna_run
25
Feb 7, 2012 09:11 AM
DelsoldS
Sep 13, 2005 02:03 PM
vietjdmboi
Mar 8, 2005 06:33 PM
Dean80Z28
13
May 20, 2004 04:12 PM
00sivtec
Dec 26, 2003 02:34 PM
