iacv on an em1
Old Mar 26, 2008 | 08:05 AM
BLK_TEG_007's Avatar
Default iacv on an em1
hey guys i want to know if the idle air control valve on a 2000 b16 can be adjusted to be fix and if so is there a write up about it
Old Mar 26, 2008 | 08:09 AM
crazyguy's Avatar
Default Re: iacv on an em1 (BLK_TEG_007)
iacv can not be adjusted.but u can clean it by using brake cleaner. if it is broken. u will need to get a new one.
Old Mar 26, 2008 | 08:12 AM
King V's Avatar
Talk to a HT user by the name of johnlear-https://honda-tech.com/zerouser...64375 . I think he said he makes/has a kit that eliminates or modifies IAC valves.
Old Mar 26, 2008 | 08:25 AM
thanks guys I've been reading on here and it said that to clean it si i cleaned it out but connected it again but it is still doing the same thing the reason i said if it could be adjusted is because i had an Ls that did the same thing but i adjusted it i wonder if advance sells it and for how much if they did
Old Mar 26, 2008 | 08:34 AM
King V's Avatar
Default Re: (BLK_TEG_007)
Its either a clean or replace thing. No real in between with IAC's. Either they work or they're ****, or the wiring is ****.
Old Mar 26, 2008 | 08:51 AM
IIXtremeHansen's Avatar
agree with all the post above. Either dirty or [freak]ed.
O2BESOHUGE
Oct 29, 2013 08:01 AM
jdmstyleEJ6
May 19, 2011 06:51 AM
paul23
Dec 23, 2009 03:39 AM
touandcim
Dec 18, 2008 06:45 PM
