97 EK Hatch Rear Disc Swap
Old Mar 26, 2008 | 06:29 AM
hondafleet82's Avatar
Default 97 EK Hatch Rear Disc Swap
I am doing a rear disc swap on my 97 EK. Where should I take the brake cables from? I know I don't have to swap out the Master Cylinder and BB but I was wondering if anyone has done the swap without changing the MC and BB and felt the need to do it at a later time. For now I am just using stock Integra discs but plan to upgrade later to something aftermarket.
Old Mar 26, 2008 | 06:31 AM
IIXtremeHansen's Avatar
Default Re: 97 EK Hatch Rear Disc Swap (hondafleet82)
Use SI cables. Dont need to upgrade Master and BB but if you want a way better feel than do it. If you have a EX model than no need to upgrade.
Old Mar 26, 2008 | 06:38 AM
EJ6_ROY's Avatar
Default Re: 97 EK Hatch Rear Disc Swap (Dickies_n_FlipFlops)
sorry to threadjack but does he need the Proportioning valve as well? I'll be doing this swap in the future.
Old Mar 26, 2008 | 06:54 AM
Blk00EJ8's Avatar
Default Re: 97 EK Hatch Rear Disc Swap (EJ6_ROY)
A 4040 prop valve would be recommended, yes. And since you're replacing the prop valve, now would be a good time to decide whether or not you want to replace the booster and master cylinder because obviously you don't want to have to bleed your brakes twice.
Like stated, both EX and Si share the same 7/8" master cylinder, but if you have a DX or equivalent then I would say it would be a good idea to also upgrade.
Old Mar 26, 2008 | 08:16 AM
EL Vap133's Avatar
Use 99-00 Si e-brake cables. If you have a DX you DO NOT need a prop valve at all, the 99-00 Si and the 96-00 DX share the same prop valve and BB. I would wait to upgrade the MC since you really don't need it until you get bigger front brakes.
Old Mar 26, 2008 | 09:53 AM
themikewoo's Avatar
Default Re: 97 EK Hatch Rear Disc Swap (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Use 99-00 Si e-brake cables. If you have a DX you DO NOT need a prop valve at all, the 99-00 Si and the 96-00 DX share the same prop valve and BB. I would wait to upgrade the MC since you really don't need it until you get bigger front brakes. </TD></TR></TABLE>
x2!
Old Mar 26, 2008 | 10:05 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafleet82 &raquo;</TD></TR><TR><TD CLASS="quote">I am doing a rear disc swap on my 97 EK. Where should I take the brake cables from? I know I don't have to swap out the Master Cylinder and BB but I was wondering if anyone has done the swap without changing the MC and BB and felt the need to do it at a later time. For now I am just using stock Integra discs but plan to upgrade later to something aftermarket. </TD></TR></TABLE>
any cable from a 92-00 civic or 94-01 integra with rear disk brakes will do (being that they are the same). as for the MC and BB, if you have a DX model, i would upgrade to a SI/EX one. if you time and money i upgraded to a 1" GSR MC and booster (i had to have custom stainless steel braided line made).
as for the prop valve, only 92-95 civic need this done so you are exempt here.
i would also recommend you replace you brake hoses with steel braided. well worth it!
Old Apr 2, 2008 | 09:31 AM
MidoriMiller's Avatar
how do you go about changing out the prop valve since some of them are shaped differently and they use hard lines?
Old Apr 2, 2008 | 10:47 AM
justinCO's Avatar
I used a full GSR rear disc setup on my EK hatch, e-brake cables and all. It works fine you just have to squeeze them a bit. Like others said, don't need prop valve, don't need MC, and ya add SS lines if you can it's a simple addition.
BTW I wrote a howto on just this here:
http://www.jackmoves.com/tech/....html
Justin
92'si
13
Mar 31, 2009 03:35 PM
nefariousyellow
Oct 21, 2007 08:00 PM
xoutlawz00x
Apr 3, 2005 06:07 PM
igone916
10
Oct 24, 2004 05:46 PM
90teg
Aug 9, 2004 02:49 PM
