vtec problem need help bad bad bad
Old Mar 26, 2008 | 06:02 AM
bulitassb1692's Avatar
Default vtec problem need help bad bad bad
Ok just swapped a b16a into my 92 civic hatch si and vtec wont work and it is idling like ruff ruff don't know y new to all this stuff so what i am asking is for some one to tell me what all does vtec need to work.
my motor is a b16a with a eldelbrock victor x intake manafoild i was told that is why it is idling bad is that true????
Old Mar 26, 2008 | 06:05 AM
yoffer's Avatar
Banned
Do you have any cel's on?
Old Mar 26, 2008 | 06:08 AM
Default Re: (yoffer)
what u mean i am ne to this stuff so u have to put it in kid form lol sry
Old Mar 26, 2008 | 06:10 AM
Probot's Avatar
Default Re: vtec problem need help bad bad bad (bulitassb1692)
do you have any Check Engine Lights (CELs)?? are all your vacuum hoses connected properly and to the right spots? could be a number of reasons for a bad idle. is it idling rough?? idling really low?? need a little more info than "ruff ruff"
does the motor have any work done to it that it hasn't gotten tuned for?? like cams or anything like that?? adjustable cam gears (doesnt require tune, but just an added part that couldve thrown something off)?? is the timing ok?
Modified by Probot at 7:16 AM 3/26/2008
Old Mar 26, 2008 | 06:18 AM
Default Re: vtec problem need help bad bad bad (Probot)
It is low but then again it wont stay at a rpm at all and ya i have a cel i know one is for a 02 and a map sensor i think and when you drive it is bogs out bad bad idk i changed intake manafoilds back to a stock one i am trying to sale the edlebrock so i can get a skunk but ya i was told that what the problem was i haven't but the stock back on yet
Old Mar 26, 2008 | 06:20 AM
Probot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulitassb1692 &raquo;</TD></TR><TR><TD CLASS="quote">It is low but then again it wont stay at a rpm at all and ya i have a cel i know one is for a 02 and a map sensor i think and when you drive it is bogs out bad bad idk i changed intake manafoilds back to a stock one i am trying to sale the edlebrock so i can get a skunk but ya i was told that what the problem was i haven't but the stock back on yet</TD></TR></TABLE>
get a new o2 sensor cause that could cause the car to bog down and idle bad, and same with the map sensor...get them both changed out, reset your ecu, and then see if anything changes.
Old Mar 26, 2008 | 06:30 AM
ok would it run like crap if the chip in my ecu is burnt up??? jw cuz i looked in there and it is brunt arount it but idk ya i am changing those out to day
does any one know of a good shop in cali ??? i am in bakerfeild cali
original_CRX
13
Apr 19, 2010 04:42 AM
Sabres_e
Oct 17, 2009 08:40 AM
lsvtec4o8
Oct 23, 2005 08:20 AM
