Disconnect hydraulic hose line? 98 accord
Old Mar 25, 2008 | 11:41 PM
Rahzel00's Avatar
Default Disconnect hydraulic hose line? 98 accord
Im stuck trying to replace my clutch master cylinder because the hydraulic line connected to it doesnt want to come off. I cant use a flare-nut wrench because the line is just round at the end, no way of gripping it? Any idea how to get these lines off? It would be nice ot be not have to take the bus again to work tomorrow..haha
Old Mar 26, 2008 | 03:26 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Disconnect hydraulic hose line? 98 accord (Rahzel00)
there should be a cotter pin I think holding the line into the clutch MC.
Should be #3 in the diagram below
Old Mar 26, 2008 | 12:06 PM
Turbowa's Avatar
Default Re: Disconnect hydraulic hose line? 98 accord (TouringAccord)
That is correct. It should come out with a little effert, but going back in is a different story. Its pretty hard to get the cotter pin back in. But be patient it will go back in.
Old Mar 26, 2008 | 12:29 PM
Rahzel00's Avatar
Default Re: Disconnect hydraulic hose line? 98 accord (Turbowa)
Thanks for the replies guys. I already had the cotter pin out but the line is still in there tight. The slave cylinder has the same connection WITHOUT the cotter pin, and it's firmly in there too, so I'm still trying to figure out how these come out?
Old Aug 3, 2015 | 05:40 PM
jeffrey23's Avatar
sorry to bring this thread back after so many years, but I'm experiencing the same problem on my accord. How did you get yours out?
Old Aug 3, 2015 | 10:23 PM
holmesnmanny's Avatar
can you take some clear pics ? It would be best to see what you got going on
Old Aug 5, 2015 | 04:59 PM
poorman212's Avatar
As the others stated there is a "roll pin" holding the line in
Old Aug 5, 2015 | 06:37 PM
What kind of idiot engineer puts a roll pin there ?
Old Aug 7, 2015 | 03:41 PM
poorman212's Avatar
A honda one
RVMIRXZem1
Aug 8, 2018 12:33 AM
Hondacar
Dec 23, 2013 10:12 PM
sideswiped
Jun 13, 2010 01:35 PM
southern_lude
Jun 26, 2005 12:00 PM
