gas mileage tranny question for the true ef guro
Old Mar 25, 2008 | 09:11 PM
JJ's civic's Avatar
Default gas mileage tranny question for the true ef guro
just took a trip in my newer civic it's a std 4spd i didn't get bad gas mileage but i can get an extra 100 miles with my dx both cars are stock for the most part both have a header and a intake the std has a muffer (not stock) and the dx had a test pipe no cat. both are dpfi. now it makes sense that the 5spd would get better but i thought the std was supose to get more???
Old Mar 25, 2008 | 11:52 PM
jpciii's Avatar
Default Re: gas mileage tranny question for the true ef guro (JJ's civic)
distance per tank is not the same as miles per gallon. You might have different size tanks.
To get MPG:
Fill up your tank.
Reset trip meter to zero.
drive, drive, drive... use a bunch of gas.
Refill your tank.
Divide the number on your trip meter by the number of gallons you just put in.
Old Mar 26, 2008 | 12:06 AM
Clipsed's Avatar
Default Re: gas mileage tranny question for the true ef guro (jpciii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpciii &raquo;</TD></TR><TR><TD CLASS="quote">distance per tank is not the same as miles per gallon. You might have different size tanks.
To get MPG:
Fill up your tank.
Refill your tank.
What he said!
Old Mar 26, 2008 | 05:24 PM
JJ's civic's Avatar
Default Re: gas mileage tranny question for the true ef guro (Clipsed)
i know that but the dx and the std have differnt size tanks??
Old Mar 26, 2008 | 05:48 PM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ’s civic &raquo;</TD></TR><TR><TD CLASS="quote">i know that but the dx and the std have differnt size tanks?? </TD></TR></TABLE>
Even if they are the same sized tank comparing the miles per tank is useless, utterly useless.
find the MPG and then compare.
Damn I am so sick of people complaining about bad milage based only on miles per tank. When you measure "miles per tank" You are counting on your gas gauge to check you mileage . You need to know that this is THE most inaccurate gauge in the vehicle! Plus you are just guessing that your tank is empty.
judging milage is inaccurate as it is, at least try to get your the measurments the standard way.
Modified by grog at 6:56 PM 3/26/2008
Old Mar 27, 2008 | 10:16 AM
JJ's civic's Avatar
Default Re: gas mileage tranny question for the true ef guro (grog)
arite i'll try it again. but do you guys think the si 5spd would get better mileage then the 4spd?
Old Mar 27, 2008 | 04:31 PM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ’s civic &raquo;</TD></TR><TR><TD CLASS="quote">arite i'll try it again. but do you guys think the si 5spd would get better mileage then the 4spd?</TD></TR></TABLE>
yeah on the highway for sure.
Old Mar 29, 2008 | 10:54 PM
jpciii's Avatar
I'm not too sure about the Si tranny getting better mileage... the 4-spd tranny is geared really really long. My guess is that they are pretty close on the highway.
As for gas tank capacities... I'm not sure of the specifics, but yeah different trim levels (and maybe different years?) had different size tanks.
Old Mar 29, 2008 | 11:26 PM
Red_ED8's Avatar
Default Re: (jpciii)
HF/STD have smaller tanks then the DX and SI. 10 gallon tanks for the HF/STD and 11.9 gallon tanks for the DX and SI (#'s might be wrong so don't quote me).
Old Mar 30, 2008 | 03:40 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpciii &raquo;</TD></TR><TR><TD CLASS="quote">I'm not too sure about the Si tranny getting better mileage... the 4-spd tranny is geared really really long. My guess is that they are pretty close on the highway.</TD></TR></TABLE>
Actualy, overall ratio is almost exactly the same between fourth gear on a STD transmission and fifth gear on an SI transmission. Fifth gear on a DX transmission is actually TALLER than fourth on a STD transmission. Given that the STD engine is so mildly cammed, it might actually give you better gas mileage on the freeway with a taller transmission.
Old Mar 30, 2008 | 10:34 AM
JJ's civic's Avatar
Default Re: (StorminMatt)
well the motor that's in the std id out of a 98 don't remeber the engine code. no vetc and it's still dpfi
Old Mar 30, 2008 | 06:26 PM
jpciii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Actualy, overall ratio is almost exactly the same between fourth gear on a STD transmission and fifth gear on an SI transmission. Fifth gear on a DX transmission is actually TALLER than fourth on a STD transmission. Given that the STD engine is so mildly cammed, it might actually give you better gas mileage on the freeway with a taller transmission.</TD></TR></TABLE>
good to know.
Old Mar 30, 2008 | 08:52 PM
Red_ED8's Avatar
Default Re: (JJ's civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ’s civic &raquo;</TD></TR><TR><TD CLASS="quote">well the motor that's in the std id out of a 98 don't remeber the engine code. no vetc and it's still dpfi</TD></TR></TABLE>
Since when is there a DPFI engine in a 98? Did you do that swap or was it in there when you bought the car and the previous owner said it was a motor from a 98?
Old Mar 30, 2008 | 09:06 PM
GLI's Avatar
GLI
Default Re: (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">HF/STD have smaller tanks then the DX and SI. 10 gallon tanks for the HF/STD and 11.9 gallon tanks for the DX and SI (#'s might be wrong so don't quote me).</TD></TR></TABLE> Yes the std has a 10 gallon tank. I get around 30mpg's.........when I'm hauling ***.
Old Mar 30, 2008 | 09:17 PM
biggee's Avatar
well the engine easily would have swapped over and to stay OBD0 they just reused the DPFi intake manifold.
Old Mar 31, 2008 | 02:13 AM
Red_ED8's Avatar
Default Re: (biggee)
Whats the engine code on the block?
Old Mar 31, 2008 | 03:20 AM
JJ's civic's Avatar
i'll look today at the code. but what happen was the used the block and reused the dpfi intake. it took it to a reg shop and had them put the motor in.
Old Mar 31, 2008 | 04:49 AM
Red_ED8's Avatar
zx2gotboost
Mar 21, 2006 07:16 PM
type Gendy
Mar 10, 2005 11:31 AM
.BigSexy
66
Feb 11, 2005 07:17 PM
goodamu
Honda S2000
21
Jan 17, 2004 05:19 AM
akeldama
12
Sep 7, 2003 02:25 PM
