97 civic hatch antenna.
Old Mar 25, 2008 | 08:12 PM
zerovandez's Avatar
Default 97 civic hatch antenna.
Anyone ever remove one of these?
I have a helms manual and its supposed to be just as easy as removing the top screws outside and pulling out the unit as a whole. A while ago one of my freinds pulled the antenna too much removing the hole metal rod thing! So i get to taking off the plastic piece outside the car. and there's nothing following it. I ordered a genuine honda antenna assembly. It looks like it's supposed to be removed as one whole unit. The rest of the old antenna is still at the bottom interior part. doesn't feel like I can yank it out, feels stuck. help.
Old Mar 25, 2008 | 08:17 PM
duefuss's Avatar
Default Re: 97 civic hatch antenna. (zerovandez)
your talking about the ant. wire right? you can get one of those bolt grabers and shove it down there and grab the wire or have fun pulling your interior apart....
Old Mar 25, 2008 | 08:22 PM
BlueIntegraBoy's Avatar
Make sure you tie some string to the end of the old antenna inside the car, that way you can pull the string to feed the new antenna in.
Old Mar 25, 2008 | 08:53 PM
zerovandez's Avatar
yeah i get what you guys are saying. thanks.
but if you've ever looked at a civic antenna it's one hole piece that's supposed to come up thought the top when removed. since my idiot buddy ripped off the top half (the metal rod with mast) theres still the wire part of it at the bottom in the driver interior. I need to remove this first before putting the new in but it feels stuck and i can pull it out.
Old Mar 25, 2008 | 08:56 PM
Default Re: (zerovandez)
Yeah, I replaced my antenna. It had the mast and the amount of wire from the bottom of the antenna. Make sure the antenna wire is not getting caught on anything under your dash.
Old Mar 25, 2008 | 09:03 PM
zerovandez's Avatar
ok well i manage to get a flashlight to look down the top out the outside. It looks like the plastic tube and the antenna wire fell down and got stuck i cant move it all. is there like a snake type tool with a grappling end?
Old Mar 25, 2008 | 09:23 PM
zerovandez's Avatar
I GOT IT OUT! I just un wound a metal clothe hanger and use the twisted end to jam it in the plastic tube enough to create friction to pull the bitch out. Thanks guys!
Matt (SG)
Dec 1, 2014 02:40 PM
SRd240sx
10
Nov 22, 2005 06:05 AM
Zing
Aug 7, 2004 03:25 PM
jolt-tsp
Oct 31, 2003 07:30 PM
.Ryan
Audio / Security / Video
Jan 23, 2003 06:23 PM
