ctr sway bar installation parts
Old Mar 25, 2008 | 07:29 PM
azn_88's Avatar
Default ctr sway bar installation parts
what do i need to install a ctr rear sway bar on a 96 cx hb. i know that i will need the subframe reinforcement kit, the bushings with the brackets over that, and ctr endlinks. do the LCA's need to be changed or will it bolt up to those too?
Old Mar 26, 2008 | 01:48 PM
azn_88's Avatar
Default Re: ctr sway bar installation parts (azn_88)
help
Old Mar 26, 2008 | 01:51 PM
SOHC4life 96's Avatar
You will need to get lower control arms that have holes for the endlinks. Either Si or EX will work.
Old Mar 26, 2008 | 01:58 PM
philosofy1's Avatar
Default Re: ctr sway bar installation parts (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">You will need to get lower control arms that have holes for the endlinks. Either Si or EX will work.</TD></TR></TABLE>
those who are lucky enough to own a 96-00 civic already have the mounting hole on the control arm, unlike 92-95 civics which need to be swapped out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azn_88 &raquo;</TD></TR><TR><TD CLASS="quote">what do i need to install a ctr rear sway bar on a 96 cx hb. i know that i will need the subframe reinforcement kit, the bushings with the brackets over that, and ctr endlinks. do the LCA's need to be changed or will it bolt up to those too?</TD></TR></TABLE>
the link i provided:http://www.thehondapartsstore.com/he...All&vinsrch=no
shows everything you will need for your 96 civic, granted i used the civic si, but it's the same concept, just add a subframe brace.
you can also call up JHP or weksos and see exactly what bolts and bracket the brace comes with. might come out cheaper than buying individual.
Old Mar 26, 2008 | 05:14 PM
azn_88's Avatar
Default Re: ctr sway bar installation parts (philosofy1)
ok so my cx rear lca's would work then. what about the front Si sway? lca's need to be changed i think.
ZombiePharoh
Suspension & Brakes
Feb 23, 2014 08:36 PM
elitesi8
27
Oct 25, 2006 01:56 AM
r1de4life
Apr 29, 2006 03:27 AM
Mr. 1582
Jan 1, 2004 08:53 PM
