ctr sway bar installation parts
what do i need to install a ctr rear sway bar on a 96 cx hb. i know that i will need the subframe reinforcement kit, the bushings with the brackets over that, and ctr endlinks. do the LCA's need to be changed or will it bolt up to those too?
Re: ctr sway bar installation parts (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">You will need to get lower control arms that have holes for the endlinks. Either Si or EX will work.</TD></TR></TABLE>
those who are lucky enough to own a 96-00 civic already have the mounting hole on the control arm, unlike 92-95 civics which need to be swapped out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azn_88 »</TD></TR><TR><TD CLASS="quote">what do i need to install a ctr rear sway bar on a 96 cx hb. i know that i will need the subframe reinforcement kit, the bushings with the brackets over that, and ctr endlinks. do the LCA's need to be changed or will it bolt up to those too?</TD></TR></TABLE>
the link i provided:http://www.thehondapartsstore.com/he...All&vinsrch=no
shows everything you will need for your 96 civic, granted i used the civic si, but it's the same concept, just add a subframe brace.
you can also call up JHP or weksos and see exactly what bolts and bracket the brace comes with. might come out cheaper than buying individual.
Re: ctr sway bar installation parts (philosofy1)
ok so my cx rear lca's would work then. what about the front Si sway? lca's need to be changed i think.
elitesi8
27
10-25-2006 01:56 AM
