BITCH pin
Old Mar 25, 2008 | 06:40 PM
jvaughn's Avatar
Default BITCH pin
no talking crap... am getting pissed to where am going to take a "saw-za" to the center of this linkage. Honestly I have tried every trick in the book... 12mm A/C bolt did not work, even raised the car to get more area to swing hammer! Tried using the C-Clamp trick and that did not work. Honeslty I think that the "BITCH pin" is rusted, should I drill out the pin? please help! thanks
jericho
Old Mar 25, 2008 | 06:46 PM
MrMug3n's Avatar
Default Re: BITCH pin (jvaughn)
i know what you mean! Cant stand that lil f*ckr but i use the exhaust bolt it fits perfect, the one right there with the spring by the cat. but sometimes it takes hundreds of swings =/ another way that works is a air impact gun with a pointed chisell, took half a sec but most dont have that handy
good luck
Old Mar 25, 2008 | 06:48 PM
97Ej6mike's Avatar
I wouldnt highly suggest drilling it out, for risk of oversizing the hole, making any future bitch pin not fit tight enough. Have you used any degreasers or PB plaster or WD 40? that may help loosen it up
Old Mar 25, 2008 | 06:55 PM
1fastVX's Avatar
Default Re: (97Ej6mike)
Do you have an air compressor? If so an air hammer will take it out in a few seconds. If you do have an air compressor available, but you dont have a air hammer you can find them real cheap at most auto parts stores.
John
Old Mar 25, 2008 | 07:16 PM
afstvx's Avatar
helll yea x3 for air hammer it makes it NOT a bitch pin. but if you dont haveacsess to one, and you have spare shift linkage i would just cut it off.
Old Mar 25, 2008 | 08:52 PM
jvaughn's Avatar
Default Re: (afstvx)
yeah the motor thats in my car has a shift linkage that came with the motor and I bought a hasport linkage that I need to install, where would I cut at the center between the "bitch pin" I have a "saw-za" , would that work?
thanks,
jericho
Old Mar 25, 2008 | 09:07 PM
Scotty Dosent Know's Avatar
Default Re: (jvaughn)
use the correct size punch and rubber mallet and it should come out some times its tuff but use the right tool for the job. You have proabably [freak]ed it up by using bolts and **** lol
Old Mar 25, 2008 | 09:15 PM
anomoly553's Avatar
Default Re: (Scotty Dosent Know)
ive done 8 swaps, and never had a problem with the "bitch pin" am i lucky or do i know what i am doing WD-40, then if you dont have air hammer, ive even gotten it out with a freakin screwdriver and a small hammerbut yes your best bet is a punch
Old Mar 25, 2008 | 10:12 PM
instrument's Avatar
f a rubber mallet, get a punch and a sledge hammer, i've never had an issue with the pin.
its easiest with two people, one to hold the punch the other to swing the sledge.
lube it up, line it up and tap away
also if you go to sears they have the punch with the little nipple type deal on it that'll keep it centered.
Old Mar 25, 2008 | 10:32 PM
radicalmarkSRT's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">f a rubber mallet, get a punch and a sledge hammer, i've never had an issue with the pin.
also if you go to sears they have the punch with the little nipple type deal on it that'll keep it centered.</TD></TR></TABLE>
f the rubber mallet. **** wont work.
Old Mar 26, 2008 | 04:02 AM
alacard's Avatar
C-clamp trick worked perfect for me...Plus, isn't it bad to be hammering something that is directly connected to your transmission?
Old Mar 26, 2008 | 05:11 AM
LS-V Turbo's Avatar
Default Re: BITCH pin (alacard)
I just pulled my trans out with the linkage conected and it worked just fine.
Old Mar 26, 2008 | 07:24 AM
jvaughn's Avatar
so by using a "punch" would I have to take the pin out from the underside of the linkage as if the pin will come out going towards the hood? Damn bitch pin, also I have thrown some WD-40 on that *****!!!!
thanks
Old Mar 26, 2008 | 07:56 AM
1992Si's Avatar
I use long 3/8 extensions from the top. I put a 7/32 allen hex bit on the end of two long 3/8 extensions and slip it down by the throttle body. Hit the extensions with a BMFH, did I say that.
The pin will fall into the ground. Done this a cazillon times.
Old Mar 26, 2008 | 10:19 AM
instrument's Avatar
on what motor can you see the pin from the top?
just wondering
Old Mar 26, 2008 | 11:08 AM
wonderB's Avatar
use a hammer and 1/4 in rachet extension and wd40 ..
Old Mar 26, 2008 | 11:15 AM
2wheelhunter's Avatar
Default Re: (wonderB)
air-chisel ftw
Old Mar 26, 2008 | 11:25 AM
PI$TOL's Avatar
* B A N N E D *
BFH and a good punch.( the right size )done. although if your trying this on the ground i've never had luck. it needs to be on a lift so you can stand up under it.
Old Mar 26, 2008 | 11:53 AM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
its not that hard...
take a 8mm roll pin punch and a hammer. 5 medium strength hits and its done.
youve probably destroyed the roll pin, and your shifter is going to be terribly sloppy.
Old Mar 26, 2008 | 01:22 PM
SimplyTron's Avatar
Probably expanded it. Air hammer or I use a door hinge pin from my front door. fits perfect.
Old Mar 26, 2008 | 01:55 PM
1992Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">on what motor can you see the pin from the top?
just wondering</TD></TR></TABLE>
D16z6 in a 92 hatch. rota92's yellow car. I had the tranny on and out more times then you want to.
allshownogo
11
Mar 20, 2008 05:59 PM
PatrickGSR94
Jun 19, 2007 11:32 AM
damn_import_culture
Aug 28, 2006 07:39 PM
streetracerof06
Oct 27, 2005 09:20 AM
clutch33
Apr 14, 2004 07:49 PM
