reseting key fob
sit in the car with all doors shut.. put the key in the ignition.. turn to the on position without starting it then to the off position.. hit lock button on key fob .. repreat process about three times until u hear the locks cycle.. once u hear the locks cycle hit lock and unlock again and you should be good **note** this procedure must be done quickly.. good luck
TeamRPM_ZC
May 30, 2008 10:58 AM
