SHIFTER BOUNCES????
Old Mar 25, 2008 | 04:45 PM
da6er's Avatar
Default SHIFTER BOUNCES????
WHEN IM IN HIGH RMS LIKE 5 AND UP AND LET OFF THE GAS MY SHIFTER KINDA DOES A BOUNCING MOVEMENT.
WHEN THE CAR KIND OF JERKS FROM THE WINDING DOWN. FEELS LIKE THE TRANNYS MOVING BUT I CHECKED THE MOUNT AND ITS NICE AND TIGHT.....
IM NOT SURE WHY THIS WOULD BE....
ANY HELP PLEASE?
Old Mar 25, 2008 | 04:56 PM
1992Si's Avatar
Unlock your caps.
IMO your mounts and bushings are getting old.
Start with the cheap $15.00 shifter bushing kit.
Then try inserts or the cheap way, fill the mounts with silicone sealant.
Old Mar 25, 2008 | 04:58 PM
da6er's Avatar
Default Re: (1992Si)
sorry i use caps at work so yeah.... anyways its a stock 2000 em1. ill try that tho.... thanx.
Old Mar 25, 2008 | 05:00 PM
schardbody's Avatar
mounts are soggy letting the engine/transmission move.
Old Mar 25, 2008 | 08:23 PM
da6er's Avatar
Default Re: (schardbody)
whats the effect on the car over all?
i need all new mounts?
Old Mar 25, 2008 | 08:27 PM
afstvx's Avatar
did it just start happening or has it always been like that. one of you motor mounts where it is actully welded to the chasis could be craked.
Old Mar 26, 2008 | 06:48 AM
da6er's Avatar
Default Re: (afstvx)
i just got the car last week
Old Mar 26, 2008 | 06:54 AM
97Ej6mike's Avatar
Sounds like a typical case of stock motor mounts.
Old Mar 26, 2008 | 07:55 AM
da6er's Avatar
Default Re: (97Ej6mike)
how long do you think i can drive like this? i dont drive fast or crazy... ... just from point A to pint B.
im going to put a C5 in the are in like 5 months.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da6er &raquo;</TD></TR><TR><TD CLASS="quote">i just got the car last week</TD></TR></TABLE>
Old Mar 26, 2008 | 07:56 AM
schardbody's Avatar
96 and newer are worse for this than any others for some reason.
usually its the rear mount that causes the most movement. start there.
Old Mar 26, 2008 | 09:09 AM
da6er's Avatar
Default Re: SHIFTER BOUNCES???? (da6er)
BUMP UP THE JAMMMMMMMMMMMM
Old Mar 26, 2008 | 09:58 AM
97Ej6mike's Avatar
E.S motor mount inserts pretty much eliminated any and all shifter movment when i got them.
Old Mar 29, 2008 | 09:12 AM
da6er's Avatar
Old Mar 30, 2008 | 09:33 PM
da6er's Avatar
swizz977
21
Apr 14, 2012 07:13 AM
boarding2008
Oct 27, 2009 01:44 PM
themunchkinman
Apr 5, 2008 04:37 AM
97grnrs
Dec 9, 2005 04:21 PM
AzntstyleZ
Feb 9, 2004 11:33 AM
