95 civic with LS won't idle once warm.
Old Mar 25, 2008 | 02:57 PM
Sil84's Avatar
Default 95 civic with LS won't idle once warm.
i just got a 1995 honda civic cx with and ls swap and it has a cel for the IAC i replace it and it is still not idling what it is doing is once the car gets warms it will die period.
not sure what the problem is but maybe some one has had this problem so if someone could help it would be nice.
Old Mar 25, 2008 | 05:51 PM
Sil84's Avatar
Default Re: 95 civic with LS won't idle once warm. (Sil84)
bump
Old Mar 25, 2008 | 05:55 PM
crazyguy's Avatar
is idel bouncing and jumping or ? what ecu are u running
Old Mar 25, 2008 | 06:17 PM
denraweb's Avatar
Default Re: 95 civic with LS won't idle once warm. (crazyguy)
sounds like a vacuum problem....check lines/hoses as well as all electrical connectors. While the car is warming up, discconnect the iacv connector and see if theres a change...if there's not, there's a wiring issue somewhere.
Old Mar 25, 2008 | 07:19 PM
Sil84's Avatar
Default Re: 95 civic with LS won't idle once warm. (denraweb)
the idle is bouncie while warming up but then once it is warm it dies. but will start right back.
and the vacuum problem wouldn't that kill it befor it is warm also if that was the problem?
Old Mar 26, 2008 | 08:30 AM
Sil84's Avatar
bump it
Old Mar 26, 2008 | 08:53 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
i kinda had the same problem with my CX but had stock motor and i tried changing my Throttle Body and the throttle body i put on it didn't have a place for the map sensor and the idle would jump and then shut off when eng light came on.... my guess would be make sure your using the right ECU and that its programed right
Old Mar 26, 2008 | 09:18 AM
97civic94gsxr's Avatar
Default Re: 95 civic with LS won't idle once warm. (hondateg10)
yeah i'm having the same problem with my ls vtec hatch it will either idle really low or just die. bump for more help
Old Mar 26, 2008 | 09:40 AM
ho bag's Avatar
Default Re: 95 civic with LS won't idle once warm. (97civic94gsxr)
First unplug the IACV and turn the base idle screw to keep it running.
Leave it running until it gets hot then adjust the screw till the base idle is about 750-850 rpm.
Shut down the car and hook the IACV back up.
At this point if the iacv is working the car should idle right.
Old May 15, 2008 | 02:04 PM
prjctwhteg's Avatar
Default Re: 95 civic with LS won't idle once warm. (ho bag)
check your throttle cable make sure it's not loose and check your idler screw
Swoops
Oct 26, 2010 07:28 PM
libral00
Jun 16, 2007 04:19 PM
RipSiTurboHatch
Jun 1, 2006 12:01 PM
mikeunreal
Oct 27, 2005 02:39 PM
hyperlite1080
Apr 19, 2004 06:56 PM
