timing problems
Distributor is advanced all the way and timing is only at 14 degrees, should be at 16 degrees before top dead center. All timing marks line up at the cam gear and crank pulley. Need help getting it to 16 degrees before top dead center... I just replaced the tensioner and the belt is tight... please help me out.... thanks
hey what engine is it, im having the same exact problem with my b18a1, cam gears are lined up right, crank is at tdc on compression stroke on cylender one but for some reason i cant figure out what to do to get the rotor in the distributor back a little further to spark cylender one
dannyk89
Nov 4, 2008 08:16 AM
