Light dimming issue + other problems
I have a 98 Civic EX, with a 1600watt audiobahn amp, 1 farad cap, and 2 12" Infinity Subs. I upgraded "The Big Three" and still have this issue. The issue is that my interior (IE gauge) and headlights have a rhythmic dimming pattern to it when i turn the headlights on. I have a new alternator (put in with in the last year, also new battery), so I don't think it could be that. Any ideas on what it could be? Could is be something with in the cluster? I have an EK cluster in it, hooked right up, but over the past few months I have been messing with the clusters that have been in there, retrofitted an 05 si one in there for a while and now I have this one, could something like a messed up wire back there be causing this?
Also when I turn my turn signal on, the speedo and tach die and return. like I'll be doing 70 and then the speedo and tach will drop to 0 then back to 70. This is regardless of whether or not the lights are on or off, and seems to do it whenever it wants. As for this, I have no idea where to even start looking.
I checked the fuses, and they look to be good, but I have not pulled and tested them yet, haven't had a chance. Any ideas y'all have are greatly appreciated!
You possibly have an electrical short in an engine wire harness. For more details, check here:
http://autorepair.about.com/li...d.htm
Townson
Jan 7, 2017 10:39 AM
crxaddikt
Jul 5, 2012 10:08 AM
ctrld-kaos
Jan 18, 2006 04:16 PM
97jdmdc2gsr
11
Jan 2, 2006 01:10 PM
